SSL Certificate - does not validade (healthcheck/status.json) [Apache NGINX port conflict]
Hello!
I need help with a problem with passbolt (v3.0.2) that I have been trying to solve for the last few days, but I haven’t gotten it fixed yet.
Our passbolt is hosted in:
  • An EC2 machine
  • OS is Ubuntu
  • It has a 20GB volume attached
  • Its hostname is defined in a Cloudfront
And it has stopped working suddenly. We thought it could be storage issues (since it happened before), but it’s only using 15GB. We don’t know exactly what happened, so I’m sharing other information about them.
Its healthcheck
 [PASS] PHP version 7.3.27-9+ubuntu18.04.1+deb.sury.org+1.
 [PASS] Full base url is set to https://pass.outsmartyourself.com.br
  [HELP] fopen(https://pass.outsmartyourself.com.br/healthcheck/status.json): failed to open stream: Connection refused
 [PASS] 25 tables found
 [FAIL] This installation is not up to date. Currently using 3.0.2 and it should be v3.12.2.
  4 error(s) found. Hang in there!
Something I thought strange and I would like to share with you is that it does not show anything running on Port 443, which explains why passbolt does not receive any response from https://pass.outsmartyourself.com.br/
sudo lsof -i -P -n | grep LISTEN
systemd-r   684 systemd-resolve   13u  IPv4   17756      0t0  TCP 127.0.0.53:53 (LISTEN)
php-fpm7.   849            root    7u  IPv4   21747      0t0  TCP 127.0.0.1:9000 (LISTEN)
sshd        850            root    3u  IPv4   20954      0t0  TCP *:22 (LISTEN)
sshd        850            root    4u  IPv6   21070      0t0  TCP *:22 (LISTEN)
apache2     923            root    4u  IPv6   21492      0t0  TCP *:80 (LISTEN)
mysqld      988           mysql   19u  IPv6   21970      0t0  TCP *:3306 (LISTEN)
php-fpm7.   989        www-data    9u  IPv4   21747      0t0  TCP 127.0.0.1:9000 (LISTEN)
php-fpm7.   990        www-data    9u  IPv4   21747      0t0  TCP 127.0.0.1:9000 (LISTEN)
apache2   23209        www-data    4u  IPv6   21492      0t0  TCP *:80 (LISTEN)
apache2   23210        www-data    4u  IPv6   21492      0t0  TCP *:80 (LISTEN)
apache2   23211        www-data    4u  IPv6   21492      0t0  TCP *:80 (LISTEN)
apache2   23213        www-data    4u  IPv6   21492      0t0  TCP *:80 (LISTEN)
apache2   23215        www-data    4u  IPv6   21492      0t0  TCP *:80 (LISTEN)
apache2   23375        www-data    4u  IPv6   21492      0t0  TCP *:80 (LISTEN)
apache2   29683        www-data    4u  IPv6   21492      0t0  TCP *:80 (LISTEN)
Hi @joaogolias Welcome to the forum!
I notice your version is outdated. Are you expecting to be running the Apache webserver or NGINX?
Did you originally install via package or source?
Hi @garrett! Thank you for your quick reply!
It was originally installed with NGINX as I saw in our install.log file.
Setting up nginx...
Synchronizing state of nginx.service with SysV service script with /lib/systemd/systemd-sysv-install.
Executing: /lib/systemd/systemd-sysv-install enable nginx
Saving debug log to /var/log/letsencrypt/letsencrypt.log
Plugins selected: Authenticator webroot, Installer None
Obtaining a new certificate
Performing the following challenges:
http-01 challenge for pass.outsmartyourself.com.br
Using the webroot path /var/www/passbolt/webroot for all unmatched domains.
Waiting for verification...
Cleaning up challenges
IMPORTANT NOTES:
 - Congratulations! Your certificate and chain have been saved at:
   /etc/letsencrypt/live/pass.outsmartyourself.com.br/fullchain.pem
   Your key file has been saved at:
   /etc/letsencrypt/live/pass.outsmartyourself.com.br/privkey.pem
   Your cert will expire on 2019-05-02. To obtain a new or tweaked
   version of this certificate in the future, simply run certbot
   again. To non-interactively renew *all* of your certificates, run
   "certbot renew"
 - If you like Certbot, please consider supporting our work by:
   Donating to ISRG / Let's Encrypt:   https://letsencrypt.org/donate
   Donating to EFF:                    https://eff.org/donate-le
We installed it in 2021 via package!
In this machine, there’s the passbolt_ce_ubuntu_installer.sh script
I guess you could stop apache2 service:
systemctl stop apache2
And start nginx:
systemctl start nginx
Run the above commands as root user or with sudo.
If it solves your issue, and if you don’t have any other service running with apache, you can disable apache2 service:
systemctl disable apache2
Thus, apache2 won’t be started on next reboot.
You should consider to migrate your passbolt to a more recent server, there are guides for this in the help site.
@AnatomicJC
Thank you so much!! It worked!!
Now there is “something” running on port 443 and Health Check shows no error (but the update one)
nginx     32734            root    8u  IPv4 2459510      0t0  TCP *:80 (LISTEN)
nginx     32734            root    9u  IPv4 2459511      0t0  TCP *:443 (LISTEN)
nginx     32734            root   10u  IPv6 2459512      0t0  TCP *:80 (LISTEN)
nginx     32738        www-data    8u  IPv4 2459510      0t0  TCP *:80 (LISTEN)
nginx     32738        www-data    9u  IPv4 2459511      0t0  TCP *:443 (LISTEN)
nginx     32738        www-data   10u  IPv6 2459512      0t0  TCP *:80 (LISTEN)
About the update itself, I’m already studying the docs to do so.
Once again, thank you very much!
