Web Proxy settings disfunction after upgrade to 4.9.0 (docker passbolt:latest)
After upgrade to 4.9.0 environment variables for HTTP_PROXY and HTTPS_PROXY do not work anymore.
compose.yml:
      HTTP_PROXY: http://our-proxy:4711/
      HTTPS_PROXY: http://our-proxy:4711/
      NO_PROXY: localhost,[...]
command:
docker exec -u www-data -it passbolt  ./bin/cake passbolt healthcheck
 [FAIL] Could not connect to passbolt repository to check versions. It is not possible to check if your version is up-to-date.
