No mails sent from passbolt
[X ] I have read the tutorials, help and searched for similar issues
[X ] I provide relevant information about my server (component names and versions, etc.)
[X ] I provide a copy of my logs and healthcheck
[X ] I describe the steps I have taken to trouble shoot the problem
[X ] I describe the steps on how to reproduce the issue
Good morning all,
After spending several hours understanding my problem, I allow myself to ask for some help here.
I installed passbolt on one of my servers (hosted by OVH). This is a debian 10, a mariadb 10.3.23-MariaDB-0 + deb10u1, and it has a postfix to relay mail. This part works very well.
I can send mail from shell, no problem:
 Debug email shell
Email configuration
Host: ssl://ssl0.ovh.net
Port: 465
Username: admin@mydomain.fr
Password: *********
TLS: false
Sending email from: admin admin@mydomain.fr
Sending email to: me@mydomain.fr
Trace
[220] GARM-96R001 Sunday, September 20, 2020
> EHLO localhost
[250] OVH SMTP PROXY Hello
[250] SIZE 104857600
[250] ENHANCEDSTATUSCODES
[250] AUTH LOGIN PLAIN
[250] AUTH=LOGIN PLAIN
[250] 8BITMIME
> AUTH LOGIN
[334] VXNlcm5hbWU6
[334] UGFzc3dvcmQ6
[235] 2.7.0 Authentication successful
> MAIL FROM:<*****>
[250] 2.1.0 Sender OK
> RCPT TO:<me@mydomain.fr>
[250] 2.1.5 Recipient OK
> DATA
[354] Start mail input; end with <CRLF>.<CRLF>
> From: admin <*****>
To: me@mydomain.fr
Date: Sun, 20 Sep 2020 08:32:47 +0000
Message-ID: <f7c76fc5552e4caf8627ec5d6c709788@server>
Subject: Passbolt test email
MIME-Version: 1.0
Congratulations!
[250] 2.6.0 <f7c76fc5552e4caf8627ec5d6c709788@server> [InternalId=41510858919472, Hostname=DAG4EX2.mxp5.local] 1643 bytes in 0.152, 10.528 KB/sec Queued mail for delivery
> QUIT
But when I want to invite via passbolt, no mail is sent.
So I run a Healthcheck to find out a little more.
[PASS] PHP version 7.3.19-1~deb10u1.
[PASS] Full base url is set to https://passbolt.mydomain.fr
fopen(https://passbolt.mydomain.fr/healthcheck/status.json): failed to open stream: operation failed
[PASS] 23 tables found
[PASS] Using latest passbolt version (2.13.5).
Could this certificate issue (generated directly from the passbolt installer) prevent this email from being sent? Which again works great.
Additionally, I noticed the following error in the logs:
Exception: SQLSTATE[HY000] [1045] Access denied for user ''@'localhost' (using password: NO) in [/usr/share/php/passbolt/vendor/cakephp/cakephp/src/Database/Driver.php, line 92]
Who is the user? www-data? the passbolt administrator of the base?
My passbolt.php:
 // Database configuration.
'Datasources' => [
        'default' => [
            'host' => '127.0.0.1',
            'port' => '3306',
            'username' => 'passboltadmin',
            'password' => 'XXXXXX',
            'database' => 'passbolt',
MySQL works for passboltadmin via shell, no problem.
Do I have to create a mysql user www-data ?
I begin to despair.
Thank you in advance.
No, the SSL certificate should not impact emails. The healthcheck is known to throw errors for self-signed certificates, so if your browser is happy with it, then it should be no problem.
Did you check:
Possible reasons:
  • The cron job to send email is missing
  • Email notifications are disabled in the config
Let us know once you checked the later
Well, I redid a pass, there was an error in the crontab … Tired after several hours …
It works !!
Thank you
@Franck glad you got it to work, have a nice weekend!
