Docker not sending emails
I am trying to get passbolt up and running in a local network. I don’t want to make my server accessible from a public IP, instead, I can access it using the local IP and connecting to a VPN that I have up and running that exposes the local network.
To get passbolt up and running I have followed the docker installation guide. The system works fine and I can add users using the docker command, also users can log in add passwords, etc, etc. So far so good!
However, we have realized that emails are not being sent. We realized when I was trying to recover an account.
Here is how I launch the docker:
docker run --name passbolt \
--net passbolt_network \
-p 443:443 -p 80:80 \
-e DATASOURCES_DEFAULT_HOST=mariadb \
-e DATASOURCES_DEFAULT_PASSWORD=mariadbpassword \
-e DATASOURCES_DEFAULT_USERNAME=mariadbusername \
-e DATASOURCES_DEFAULT_DATABASE=passbolt_db \
-e APP_FULL_BASE_URL=https://192.168.8.241 \
-e EMAIL_DEFAULT_FROM=myemail@myemailserver.com \
-e EMAIL_TRANSPORT_DEFAULT_HOST=smtp.myemailserver.es \
-e EMAIL_TRANSPORT_DEFAULT_PORT=587 \
-e EMAIL_TRANSPORT_DEFAULT_TLS=true \
-e EMAIL_TRANSPORT_DEFUALT_USERNAME=myemail@myemailserver.com \
-e EMAIL_TRANSPORT_DEFAULT_PASSWORD=mypassword \
passbolt/passbolt:latest
Here is the healthcheck su -s /bin/bash -c "./bin/cake passbolt healthcheck" www-data
Warning Error: SplFileInfo::openFile(/var/www/passbolt/tmp/cache/persistent/myapp_cake_core_translations_default_en__u_s): failed to open stream: Permission denied in [/var/www/passbolt/vendor/cakephp/cakephp/src/Cache/Engine/FileEngine.php, line 406]
Warning Error: SplFileInfo::openFile(/var/www/passbolt/tmp/cache/models/myapp_cake_model_default_organization_settings): failed to open stream: Permission denied in [/var/www/passbolt/vendor/cakephp/cakephp/src/Cache/Engine/FileEngine.php, line 406]
Warning Error: _cake_model_ cache was unable to write 'default_organization_settings' to Cake\Cache\SimpleCacheEngine cache in [/var/www/passbolt/vendor/cakephp/cakephp/src/Cache/Cache.php, line 306]
Warning Error: SplFileInfo::openFile(/var/www/passbolt/tmp/cache/persistent/myapp_cake_core_translations_cake_console_en__u_s): failed to open stream: Permission denied in [/var/www/passbolt/vendor/cakephp/cakephp/src/Cache/Engine/FileEngine.php, line 406]
 [PASS] PHP version 7.3.21.
 [FAIL] The temporary directory and its content are not writable.
  [HELP] you can try:
  [HELP] sudo chown -R www-data:www-data /var/www/passbolt/tmp/
  [HELP] sudo chmod 775 $(find /var/www/passbolt/tmp/ -type d)
  [HELP] sudo chmod 664 $(find /var/www/passbolt/tmp/ -type f)
 [PASS] Full base url is set to https://192.168.8.241
  [HELP] cURL Error (28) Connection timed out after 30001 milliseconds
 [PASS] 23 tables found
  [HELP] sudo su -s /bin/bash -c "gpg --list-keys --fingerprint --home /home/www-data/.gnupg" www-data | grep -i -B 2 'SERVER_KEY_EMAIL'
  [HELP] you can try:
  [HELP] sudo su -s /bin/bash -c "gpg --home /home/www-data/.gnupg --import /var/www/passbolt/config/gpg/serverkey_private.asc" www-data
 [PASS] Using latest passbolt version (2.13.5).
  8 error(s) found. Hang in there!
Here is what I get when I try to send a test email ./bin/cake passbolt send_test_email
 Debug email shell
Email configuration
Host: smtp.myemailserver.es
Port: 587
Username:
Password: *********
TLS: true
Sending email from: myemail@myemailserver.com
Sending email to: doesnotexist@passboltdummydomain.com
Trace
[220] kundenserver.de (mreue011) Nemesis ESMTP Service ready
> EHLO localhost
[250] kundenserver.de Hello localhost [PUBLIC.IP.OF.MYROUTER]
[250] 8BITMIME
[250] AUTH LOGIN PLAIN
[250] SIZE 140000000
[250] STARTTLS
> STARTTLS
[220] OK
> EHLO localhost
[250] 8BITMIME
A test email could not be sent.
Error: SMTP Error: 530 Authentication required
Any ideas/hints on how to solve this issue?
I have gone through some of the forums claiming similar issues without success. here is a list of what I have tried already:
Hi @apalomer,
Can you confirm your email server is using TLS? There are subtle configuration differences depending if the provider uses TLS, SSL or none of them. You can check https://help.passbolt.com/configure/email/setup
What looks weird is those permission denied messages. Those are not suppossed to happen, have you changed any permissions on the docker image/ built your own docker image?
I have the same email configured as an alias in gmail so I can send emails using this account from my gmail and I have checked the TLS option when I configured and it works, so I assume the credentials and tls options are right.
I have looked into the email/setup that you shared and it only says to put the environmental variables as I showed in my docker run command.
I haven’t been able to reproduce your issue.
For my tests I have been using the default https://github.com/passbolt/passbolt_docker/blob/master/docker-compose.yml
I have edited the env/passbolt.env file adding the following env variables:
EMAIL_TRANSPORT_DEFAULT_HOST=smtp.gmail.com EMAIL_TRANSPORT_DEFAULT_PASSWORD=__PASS__ EMAIL_TRANSPORT_DEFAULT_USERNAME=__USERNAME__ EMAIL_TRANSPORT_DEFAULT_PORT=587 EMAIL_TRANSPORT_DEFAULT_TLS=true
But after all my tests I just realized you have a typo in your env variables:
I think that is the problem :sweat_smile:
OMG! My dislexia is very bad… thank you very much, ./bin/cake passbolt send_test_email --recipient=myemail@mydomain.com just worked fine now!
