Not able to send emails with SMTP in docker setup
Hello. Im trying to set up passbolt using this docker setup. Everything works except for email sending via SMTP, thus users cannot register to my passbolt instance. Since I made some changes in the docker-compose file to fit my infrastructure details, I’ll post it here. The idea is to run passbolt with a google cloud database, besides nginx and certbot.
System Information
OS
Distro: Ubuntu 20.04 LTS x86_64
Host: Google Compute Engine
Kernel: 5.4.0-1019-gcp
Shell: bash 5.0.16
CPU: Intel Xeon (1) @ 2.300GHz
Memory: 392MiB / 3683MiB
MYSQL 5.7 on Gcloud
Web server
Its a docker image of nginx: nginx:1.19.1-alpine
Logs
Healthcheck
Healthcheck shell…
[PASS] PHP version 7.3.19.
[PASS] Full base url is set to https://passbolt-stg.taqtile.dev
[PASS] 23 tables found
[PASS] Using latest passbolt version (2.13.1).
[WARN] Registration is open to everyone.
[HELP] Or set passbolt.registration.public to false in config/passbolt.php.
cli-debug.log
2020-07-14 19:22:17 Debug: command 'preview' in plugin 'EmailQueue' was not aliased, conflicts with 'Passbolt/EmailDigest'
2020-07-14 19:22:17 Debug: command 'sender' in plugin 'EmailQueue' was not aliased, conflicts with 'Passbolt/EmailDigest'
error.log
2020-07-14 22:06:03 Error: [Cake\Routing\Exception\MissingRouteException] A route matching "/owa/auth/logon.aspx" could not be found. (/var/www/passbolt/vendor/cakephp/cakephp/src/Routing/RouteCollection.php:216)
Request URL: /owa/auth/logon.aspx?url=https%3a%2f%2f1%2fecp%2f
2020-07-14 22:39:01 Error: [Cake\Routing\Exception\MissingRouteException] A route matching "/webfig/" could not be found. (/var/www/passbolt/vendor/cakephp/cakephp/src/Routing/RouteCollection.php:216)
Request URL: /webfig/
2020-07-15 00:37:41 Error: [Cake\Routing\Exception\MissingRouteException] A route matching "/webfig/" could not be found. (/var/www/passbolt/vendor/cakephp/cakephp/src/Routing/RouteCollection.php:216)
Referer URL: http://35.192.84.251/webfig/
2020-07-15 01:04:47 Error: [Cake\Routing\Exception\MissingRouteException] A route matching "/Telerik.Web.UI.WebResource.axd" could not be found. (/var/www/passbolt/vendor/cakephp/cakephp/src/Routing/RouteCollection.php:216)
Request URL: /Telerik.Web.UI.WebResource.axd?type=rau
2020-07-15 01:12:02 Error: [Cake\Routing\Exception\MissingRouteException] A route matching "/Telerik.Web.UI.WebResource.axd" could not be found. (/var/www/passbolt/vendor/cakephp/cakephp/src/Routing/RouteCollection.php:216)
Referer URL: http://35.192.84.251/Telerik.Web.UI.WebResource.axd?type=rau
2020-07-15 13:02:43 Error: [Cake\Routing\Exception\MissingRouteException] A route matching "/solr/admin/info/system" could not be found. (/var/www/passbolt/vendor/cakephp/cakephp/src/Routing/RouteCollection.php:216)
Request URL: /solr/admin/info/system?wt=json
Referer URL: http://35.192.84.251:80/solr/admin/info/system?wt=json
2020-07-15 13:03:28 Error: [Cake\Routing\Exception\MissingRouteException] A route matching "s=/Index/\think\app/invokefunction&function=call_user_func_array&vars[0]=md5&vars[1][]=HelloThinkPHP" could not be found. (/var/www/passbolt/vendor/cakephp/cakephp/src/Routing/RouteCollection.php:216)
Request URL: s=/Index/%5Cthink%5Capp/invokefunction&function=call_user_func_array&vars%5B0%5D=md5&vars%5B1%5D%5B%5D=HelloThinkPHP?s=/Index/%5Cthink%5Capp/invokefunction&function=call_user_func_array&vars%5B0%5D=md5&vars%5B1%5D%5B%5D=HelloThinkPHP
Referer URL: http://35.192.84.251:80/index.php?s=/Index/\think\app/invokefunction&function=call_user_func_array&vars[0]=md5&vars[1][]=HelloThinkPHP
2020-07-15 13:09:32 Error: [Cake\Routing\Exception\MissingRouteException] A route matching "/api/jsonws/invoke" could not be found. (/var/www/passbolt/vendor/cakephp/cakephp/src/Routing/RouteCollection.php:216)
Request URL: /api/jsonws/invoke
Referer URL: http://35.192.84.251:80/api/jsonws/invoke
Env variables
APP_FULL_BASE_URL=https://passbolt.domain.com
# Database settings
DATASOURCES_DEFAULT_HOST=10.10.10.10
DATASOURCES_DEFAULT_USERNAME=company
DATASOURCES_DEFAULT_PASSWORD=fakepassword123
DATASOURCES_DEFAULT_DATABASE=passbolt
DATASOURCES_QUOTE_IDENTIFIER=true
# Email
EMAIL_DEFAULT_FROM=no-reply@domain.com
EMAIL_TRANSPORT_DEFAULT_URL=https://passbolt.domain.com
EMAIL_TRANSPORT_DEFAULT_CLASS_NAME=Smtp
EMAIL_DEFAULT_TRANSPORT=default
EMAIL_TRANSPORT_DEFAULT_TLS=true
EMAIL_TRANSPORT_DEFAULT_HOST=smtp-relay.gmail.com
EMAIL_TRANSPORT_DEFAULT_PORT=587
EMAIL_TRANSPORT_DEFAULT_USERNAME=no-reply@domain.com
EMAIL_TRANSPORT_DEFAULT_PASSWORD=fakepassword
# Registration
PASSBOLT_REGISTRATION_PUBLIC=true
docker-compose.yml
version: '3.4'
    image: passbolt/passbolt:2.13.1-debian
    container_name: passbolt
    tty: true
    env_file:
      - env/passbolt.env
      - gpg_volume:/var/www/passbolt/config/gpg
      - images_volume:/var/www/passbolt/webroot/img/public
    tmpfs:
      - /run
    command: ["/docker-entrypoint.sh"]
  nginx:
    image: nginx:1.19.1-alpine
    restart: unless-stopped
      - ./data/nginx:/etc/nginx/conf.d
      - ./data/certbot/conf:/etc/letsencrypt
      - ./data/certbot/www:/var/www/certbot
      - 80:80
      - 443:443
    command: "/bin/sh -c 'while :; do sleep 6h & wait $${!}; nginx -s reload; done & nginx -g \"daemon off;\"'"
  certbot:
      image: certbot/certbot
      entrypoint: "/bin/sh -c 'trap exit TERM; while :; do certbot renew; sleep 12h & wait $${!}; done;'"
  gpg_volume:
  images_volume:
send_test_mail
./bin/cake passbolt send_test_email --recipient=youremail@domain.com
 Debug email shell
Your email transport configuration is not set to use "Smtp". (https is set instead)
This email debug task is only for SMTP configurations.
To fix this, edit EmailTransport.default.className property in /config/passbolt.php, and set className to "Smtp"
I didnt do much besides trying to test different env variable values and do some research on this forum for similar problems. The send_test_mail output suggest that className its not getting set it right, but I don’t know if this is relevant for a docker setup.
Inside the passbolt container, I also tried to create a config/passbolt.php file based on config/passbolt.default.php with the right values for EmailTransport.default.className, but the same result was shown on send_test_mail tool.
You do not need to set these. I this the EMAIL_TRANSPORT_DEFAULT_URL is the issue and leaving it empty should work.
