] I have read intro post: About the Installation Issues category
] I have read the tutorials, help and searched for similar issues
] I provide relevant information about my server (component names and versions, etc.)
] I provide a copy of my logs and healthcheck
] I describe the steps I have taken to trouble shoot the problem
] I describe the steps on how to reproduce the issue
Hi community,
I have recently joined the Passbolt Club and setup a Docker installation of the CE version on an Ubuntu VM.
Passbolt Version: CE
Host: Docker
Host System: Ubuntu 24
Image: passbolt/passbolt:4.8.0-1-ce
And everything worked on the first try.
- Admin account added
- Set up Two Factor Authentication
- Added a test user
- Passwords created and Shared
So a fully functional installation.
And after veryfing that I proceeded to follow the Guide to get a Let’s Encrypt Certificate setup via Traefik.
(Docker automatic HTTPS configuration | Passbolt documentation.)
But after doing that I now get a NS_ERROR_REDIRECT_LOOP error when navigating to the subdomain.
I have replaced sensitive info in the following files with "<< something >> "
I have veryfied that i have a valid Certificate by looking at the /shared/acme.json file:
Excerpt from acme.json
"Registration": {
"body": {
"status": "valid",
"contact": [
"mailto:<<my-email>>"
I have also veryfied that the passbolt container recieves the routed request from Traefik by looking at the passbolt logs:
docker-compose -f docker-compose-ce.yaml logs -f passbolt
And observing activity there when eighter my plugin or my website request tries to access the URL.
Docker Compose File
version: "3.9"
db:
image: mariadb:10.11
restart: unless-stopped
MYSQL_DATABASE: "passbolt"
MYSQL_USER: "passbolt"
MYSQL_PASSWORD: "<<db-password>>"
image: passbolt/passbolt:4.8.0-1-ce
depends_on:
- db
APP_FULL_BASE_URL: https://passbolt.<<my-domain>>
DATASOURCES_DEFAULT_PASSWORD: "<<db-password>>"
EMAIL_DEFAULT_FROM: "<<my email>>"
EMAIL_TRANSPORT_DEFAULT_HOST: "smtp.<<my-smtp-server>>"
EMAIL_TRANSPORT_DEFAULT_PORT: "587"
EMAIL_TRANSPORT_DEFAULT_USERNAME: "<<my email>>"
EMAIL_TRANSPORT_DEFAULT_PASSWORD: "<<smtp-password>>"
PASSBOLT_SSL_FORCE: "true"
command:
"/usr/bin/wait-for.sh",
"-t",
"0",
"db:3306",
"/docker-entrypoint.sh",
labels:
traefik.enable: "true"
traefik.http.routers.passbolt-http.rule: "Host(`passbolt.<<my-domain>>`)"
traefik.http.routers.passbolt-https.rule: "Host(`passbolt.<<my-domain>>`)"
#ports:
# - 80:80
# - 443:443
# - 80:8080
# - 443:4433
traefik:
image: traefik:2.10.5
restart: always
- 80:80
- 443:443
- ./conf/:/etc/traefik/conf
- ./shared/:/shared
database_volume:
gpg_volume:
jwt_volume:
traefik.yaml
global:
sendAnonymousUsage: false
log:
level: INFO
format: common
providers:
docker:
endpoint: 'unix:///var/run/docker.sock'
watch: true
exposedByDefault: true
swarmMode: false
file:
directory: /etc/traefik/conf/
watch: true
api:
dashboard: false
debug: false
insecure: false
entryPoints:
web:
address: ':80'
http:
redirections:
entryPoint:
to: websecure
scheme: https
permanent: true
websecure:
address: ':443'
certificatesResolvers:
letsencrypt:
acme:
email: <<my-email>>
storage: /shared/acme.json
caServer: 'https://acme-v02.api.letsencrypt.org/directory'
keyType: EC256
httpChallenge:
entryPoint: web
tlsChallenge: {}
conf/tls.yaml
tls:
options:
default:
minVersion: VersionTLS12
sniStrict: true
curvePreferences:
- CurveP521
- CurveP384
cipherSuites:
- TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256
- TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384
- TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305_SHA256
conf/headers.yaml
http:
middlewares:
SslHeader:
headers:
FrameDeny: true
AccessControlAllowMethods: 'GET,OPTIONS,PUT'
AccessControlAllowOriginList:
- origin-list-or-null
AccessControlMaxAge: 100
AddVaryHeader: true
BrowserXssFilter: true
ContentTypeNosniff: true
ForceSTSHeader: true
STSIncludeSubdomains: true
STSPreload: true
ContentSecurityPolicy: default-src 'self' 'unsafe-inline'
CustomFrameOptionsValue: SAMEORIGIN
ReferrerPolicy: same-origin
PermissionsPolicy: vibrate 'self'
STSSeconds: 315360000
To get the healcheck data i opened a shell inside the passbolt container and executed:
su -s /bin/bash -c "/usr/share/php/passbolt/bin/cake passbolt healthcheck" www-data
And I got:
Healthcheck Output
warning: 512 :: SplFileInfo::openFile(/var/lib/passbolt/tmp/cache/persistent/myapp_cake_core_translations.cake_console.en_UK): Failed to open stream: Permission denied on line 393 of /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Cache/Engine/FileEngine.php
Healthcheck shell.....
[PASS] PHP version 8.2.18.
[FAIL] The temporary directory and its content are not writable, or are executable.
[HELP] you can try:
[HELP] sudo chown -R www-data:www-data /var/lib/passbolt/tmp/
[HELP] sudo chmod -R 775 $(find /var/lib/passbolt/tmp/ -type d)
[HELP] sudo chmod -R 664 $(find /var/lib/passbolt/tmp/ -type f)
[PASS] Full base url is set to <<my-domain>>
SMTP settings
[HELP] You can try:
[HELP] you can try:
[PASS] Using latest passbolt version (4.8.0).
[PASS] 31 tables found.
[FAIL] 10 error(s) found. Hang in there!
And that looks alot like what I got from the healthcheck section on the Website before adding Treafik. But not entirely the same.
Could anyone explain to me how I can debug this behavior? Or did I miss something in the Guides?
Any help would be amazing, thank you for reading all this!
