I have installed Passbolt CE (Docker version) on a server that uses Apache2 as a reverse proxy. The installation went smoothly, and the health check shows no issues. I created an admin user, but when I try to log in with this user’s email address, I get the message:
Access to this service requires an invitation.
This email is not associated with any approved users on this domain. Please contact your administrator to request an invitation link.
This front-end message is rather misleading, because the Docker log reports the following error:
error: [Cake\Http\Exception\InvalidCsrfTokenException] Missing or incorrect CSRF cookie type. in /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Http/Middleware/CsrfProtectionMiddleware.php on line 392
When I check the submitted request header, I do see that X-CSRF-TOKEN is set correctly, but I suspect that it somehow gets dropped when passing through the reverse proxy. Previously I have set-up Passbolt using a Cloudflare tunnel and I never encountered this issue, reinforcing my suspicion.
I have tried to “manually” re-insert the X-CSRF-TOKEN from the csrfToken cookie, but this didn’t make any difference. Any ideas on how to debug/fix this?
Apache2 config:
<VirtualHost *:443>
ServerName [redacted]
ServerAdmin [redacted]
RewriteCond %{DOCUMENT_ROOT}/%{REQUEST_FILENAME} !-f
RewriteRule .* https://127.0.0.1:4543%{REQUEST_URI} [P,QSA,L]
# RequestHeader set X-Forwarded-Proto "https"
# My attempt at fixing the request header
# SetEnvIf Cookie "(^|;\ *)csrfToken=([^;\ ]+)" MyCookieValue=$2
# RequestHeader set X-CSRF-Token "%{MyCookieValue}e"
Timeout 28800
KeepAlive On
<Location /pass>
ProxyPreserveHost On
ProxyPass https://127.0.0.1:4543
ProxyPassReverse https://127.0.0.1:4543
ProxyPassReverseCookieDomain 127.0.0.1 [redacted]
</Location>
SSLEngine on
SSLProxyEngine on
SSLCertificateFile /etc/letsencrypt/live/[redacted]/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/[redacted]/privkey.pem
Include /etc/letsencrypt/options-ssl-apache.conf
</VirtualHost>
Health check result:
Healthcheck shell...............................................................
[INFO] Linux ee4eb03b429f 5.4.0-204-generic #224-Ubuntu SMP Thu Dec 5 13:38:28 UTC 2024 x86_64 GNU/Linux
[PASS] PHP version 8.2.26.
[HELP] See `timedatectl | grep -i -A 1 clock`. More information: https://www.passbolt.com/docs/hosting/configure/ntp/
[PASS] Full base url is set to https://[redacted]
SMTP settings
[PASS] Using latest passbolt version (4.11.0).
[WARN] Host availability checking is disabled.e
[WARN] Some email notifications are disabled by the administrator.e
[PASS] 34 tables found.
[PASS] No error found. Nice one, sparky!
