GPG verify fails (Other actions)
Am doing a fresh install of our passbolt environment and I believe i might have found a bug in the newest version.
Using passbolt 2.3
on Ubuntu 16.04
./bin/cake passbolt healthcheck
 Healthcheck shell......Notice Error: Undefined variable: decryptedMessage2 in [/data/www/passbolt/src/Utility/Healthchecks/GpgHealthchecks.php, line 278]
2018-09-06 10:03:07 Notice: Notice (8): Undefined variable: decryptedMessage2 in [/data/www/passbolt/src/Utility/Healthchecks/GpgHealthchecks.php, line 278]
Notice Error: Undefined variable: decryptedMessage2 in [/data/www/passbolt/src/Utility/Healthchecks/GpgHealthchecks.php, line 279]
2018-09-06 10:03:07 Notice: Notice (8): Undefined variable: decryptedMessage2 in [/data/www/passbolt/src/Utility/Healthchecks/GpgHealthchecks.php, line 279]
 [PASS] PHP version 7.0.30-0ubuntu0.16.04.1.
 [PASS] Full base url is set to https://passbolt.widgets.nl
 [PASS] 18 tables found
 [PASS] Using latest passbolt version (2.3.0).
Running gpg from commandline works and shows key
www-data@web01:/data/www/passbolt$ gpg2 --list-keys --fingerprint
/var/www/.gnupg/pubring.gpg
pub rsa4096/72522DF4 2018-09-06 [SC]
Key fingerprint = 6166 XX
uid [ unknown] XXX
sub rsa4096/XXXX2018-09-06 [E]
www-data@web01:/data/www/passbolt$ gpg --list-keys --fingerprint
pub   4096R/72522DF4 2018-09-06
      Key fingerprint = 6166 XXX
uid                  XXX
sub   4096R/XXXX2018-09-06
[ X ] I have read intro post: About the Installation Issues category
[ X ] I have read the tutorials, help and searched for similar issues
A few topics exist but none with this specific issue.
[ X ] I provide relevant information about my server (component names and versions, etc.)
[ X ] I provide a copy of my logs and healthcheck
[ X ] I describe the steps I have taken to trouble shoot the problem
[ X ] I describe the steps on how to reproduce the issue
I wasn’t sure if I was messing up or not. So i did a full clean install of ubuntu and followed this tutorial step by step:
It ran into the same issue.
install steps. Because this is ubuntu 16.04 I have a few things that are different. They are listed below.
apt install phpmyadmin mysql-server
apt-get install make git-core composer unzip g++ linux-headers-amd64 -y
apt-get install make git-core composer unzip g++ -y
a2enmod rewrite
apt-get install php7.0 php7.0-cli php7.0-common libapache2-mod-php7.0 php7.0-json php7.0-readline php7.0-mysqlnd libonig4 libqdbm14 -y
apt-get install php7.0 php7.0-cli php7.0-common libapache2-mod-php7.0 php7.0-json php7.0-readline php7.0-mysqlnd  libqdbm14 -y
apt-get install libgpgme11-dev php7.0-gnupg -y
apt-get install libgpgme11-dev php-gnupg -y
systemctl restart apache2
nano /etc/apache2/sites-enabled/000-default.conf
nano /etc/hosts
cd /var/www
git clone https://github.com/passbolt/passbolt_api.git ./passbolt
apt-get install haveged -y
gpg --gen-key
gpg --armor --export
chmod 640 /var/www/passbolt/config/gpg/serverkey*
chown www-data:www-data /var/www
sudo su -s /bin/bash -c "gpg --list-keys" www-data
chown -R  www-data:www-data /var/www/passbolt
cd /var/www/passbolt
su -s /bin/bash www-data
apt install php7.0-intl
apt install php7.0-curl
apt install libonig2
linux-headers-amd64 >> default installed
php7.0-gnupg >> is called php-gnupg
libonig4 >> only version 2 is available
Hmm it seems that php-gnupg does not have the correct package to verify. The solution is as follows:
sudo apt remove php-gnupg
sudo pecl install gnupg
extension=gnupg.so >> php.ini
EDIT:
The timeline is a bit screwed up. The first post was a draft that I already wrote but never posted.
