Hi Passbolt Community,
I have read through the “RTFM” checklist.
– Server operating system name and version: Ubuntu 19.10
– Web server name and version: Apache 2.4.41
– Database server name and version: mysqld Ver 8.0.19-0ubuntu0.19.10.3
– Php version: 7.3.11
– Passbolt version: latest from GitHub
I have a fresh install of Passbolt from source on Ubuntu 19.10 and after running health check, I see:
[PASS] PHP version 7.3.11-0ubuntu0.19.10.2.
[PASS] Full base url is set to https://192.168.2.210
[HELP] cURL Error (60) SSL certificate problem: self signed certificate
[PASS] 23 tables found
[FAIL] The private key cannot be used to sign a message
[HELP] Make sure that the server private key is valid and that there is no passphrase.
[HELP] Make sure you imported the private server key in the keyring of the webserver user.
[HELP] you can try:
[HELP] sudo su -s /bin/bash -c "gpg --home /var/www/.gnupg --import /var/www/passbolt/config/gpg/serverkey_private.asc" www-data
[FAIL] The public and private keys cannot be used to encrypt and sign a message
[PASS] Using latest passbolt version (2.12.0).
8 error(s) found. Hang in there!
We’re looking to host this internally only (by IP address) for the time being so I’ve set it to 192.168.2.210 - is that a problem? I can add a DNS entry if necessary, but is it a must have?
