It was unfortunately locked before I could reply/resolve the issue.
Most recently, here’s my status check/health check:
user@passbolt-server-ubuntu-19-10:/var/www/passbolt$ sudo su -s /bin/bash -c "./bin/cake passbolt healthcheck" www-data
[PASS] PHP version 7.3.11-0ubuntu0.19.10.3.
[PASS] Full base url is set to https://192.168.1.42
[HELP] cURL Error (7) Failed to connect to 192.168.1.42 port 443: Connection refused
[PASS] 1 tables found
[HELP] sudo su -s /bin/bash -c "/var/www/passbolt/bin/cake passbolt install" www-data
[HELP] sudo su -s /bin/bash -c "/var/www/passbolt/bin/cake migrations migrate --no-lock" www-data
[FAIL] The environment variable GNUPGHOME is set to /home/www-data/.gnupg, but the directory does not exist.
[HELP] Ensure the keyring location exists and is accessible by the webserver user.
[HELP] you can try:
[HELP] sudo mkdir /home/www-data/.gnupg
[HELP] sudo chown -R www-data:www-data /home/www-data/.gnupg
[HELP] sudo chmod 700 /home/www-data/.gnupg
[HELP] You can change the location of the keyring by editing the GPG.env.setenv and GPG.env.home variables in config/passbolt.php.
[FAIL] The public key file is not defined in config/passbolt.php or not readable.
[HELP] Ensure the public key file is defined by the variable passbolt.gpg.serverKey.public in config/passbolt.php.
[HELP] Ensure there is a public key armored block in the key file.
[HELP] Ensure the public key defined in config/passbolt.php exists and is accessible by the webserver user.
[FAIL] The private key file is not defined in config/passbolt.php or not readable.
[HELP] Ensure the private key file is defined by the variable passbolt.gpg.serverKey.private in config/passbolt.php.
[HELP] Ensure there is a private key armored block in the key file.
[HELP] Ensure the private key defined in config/passbolt.php exists and is accessible by the webserver user.
[HELP] sudo su -s /bin/bash -c "gpg --list-keys --fingerprint --home /home/www-data/.gnupg" www-data | grep -i -B 2 'SERVER_KEY_EMAIL'
[HELP] you can try:
[HELP] sudo su -s /bin/bash -c "gpg --home /home/www-data/.gnupg --import /var/www/passbolt/config/gpg/serverkey_private.asc" www-data
[PASS] Using latest passbolt version (2.12.0).
12 error(s) found. Hang in there!
When I go to re-run the install script with sudo su -s /bin/bash -c "./bin/cake passbolt install --force" www-data in /var/www/passbolt, I get:
user@server:/var/www/passbolt$ sudo su -s /bin/bash -c "./bin/cake passbolt install --force" www-data
The GnuPG config for the server is not available or incomplete
Please run ./bin/cake passbolt healthcheck for more information and help.
So clearly something is wrong with my GnuPG set-up. I believe this relates back to my problems explained in the previous post (404s after fresh install on Ubuntu 19.10).
[PASS] Full base url is set to http://192.168.1.42
[PASS] 23 tables found
4 error(s) found. Hang in there!
Finally got this working. Apparently the .htaccess in /var/www/html was:
root@mamabear:/var/www/passbolt# cat /var/www/passbolt/.htaccess
# Uncomment the following to prevent the httpoxy vulnerability
# See: https://httpoxy.org/
#<IfModule mod_headers.c>
# RequestHeader unset Proxy
#</IfModule>
<IfModule mod_rewrite.c>
RewriteEngine on
RewriteRule ^$ webroot/ [L]
RewriteRule (.*) webroot/$1 [L]
</IfModule>
I then noticed that the Apache set-up on this Ubuntu box happened to have no mod_rewrite, so I enabled it with:
root@server:/var/www/passbolt# sudo a2enmod rewrite
Enabling module rewrite.
To activate the new configuration, you need to run:
systemctl restart apache2
root@server:/var/www/passbolt# systemctl restart apache2
Then, the site started loading! I’m running through the install now. Yay.
