After update to 3.9.0, my instance not work anymore :(
Hello everyone :smiley:
After update my server, the page doesn’t open anymore. Before update, everything was working fine. I do not make any change on the server. Just run a dnf install – refresh, and after update nothing worked anymore. I tried edit passbolt.php, delete and put the keys on the folder again, but nothing happens. I have a dump of Database and i can use all commands of MySQL and see the tables and logins, but not the passwords… If i can see the data of password, will create a fresh configuration. Have in hands, all the recovery.txt files of all user, if necessary to see the data.
I miss something?
I tried to use the command after update:
sudo -H -u nginx bash -c “/usr/share/php/passbolt/bin/cake cache clear_all”
Used too, to see de heathcare:
sudo -H -u nginx bash -c “/usr/share/php/passbolt/bin/cake passbolt healthcheck”
Attachment imgs, of the erros in my scenario.
The system is a Rocket Linux 8.7
Hope! Cheers :smiley:
@Dimmebag I’m noticing your url is http with an ip address but in the SSL section it says your cert is okay. Your fullBaseUrl should be https with your domain name.
Can you check the error log file of passbolt if there is any additional information.
/var/log/passbolt/error.log
@garrett i have a full screenshot of all sector of the healthcare, will post the log @cedric
see:
If you can copy and paste the text that will be easier for reading. If your terminal doesn’t automatically copy when selecting text, try either selecting then right clicking and copy or highlighting the text and then Ctrl-Shift-C.
@cedric
All information in my log file, in that directory:
2023-01-30 13:38:13 error: [Cake\Http\Exception\InternalErrorException] The authentication failed. in /usr/share/php/passbolt/src/Controller/Auth/AuthLoginController.php on line 93
Request URL: /auth/verify.json?api-version=v2
Client IP: 10.0.110.132
2023-01-30 13:38:13 error: The authentication failed.
2023-01-30 13:38:13 error: #0 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Controller/Controller.php(539): App\Controller\Auth\AuthLoginController->loginPost()
#1 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Controller/ControllerFactory.php(140): Cake\Controller\Controller->invokeAction()
#2 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Controller/ControllerFactory.php(115): Cake\Controller\ControllerFactory->handle()
#3 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Http/BaseApplication.php(317): Cake\Controller\ControllerFactory->invoke()
#4 /usr/share/php/passbolt/src/Application.php(131): Cake\Http\BaseApplication->handle()
#5 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Http/Runner.php(77): App\Application->handle()
#6 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Http/Middleware/SecurityHeadersMiddleware.php(255): Cake\Http\Runner->handle()
#7 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Http/Runner.php(73): Cake\Http\Middleware\SecurityHeadersMiddleware->process()
#8 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Http/Middleware/CsrfProtectionMiddleware.php(138): Cake\Http\Runner->handle()
#9 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Http/Runner.php(73): Cake\Http\Middleware\CsrfProtectionMiddleware->process()
#10 /usr/share/php/passbolt/plugins/PassboltCe/JwtAuthentication/src/Middleware/JwtCsrfDetectionMiddleware.php(55): Cake\Http\Runner->handle()
#11 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Http/Runner.php(73): Passbolt\JwtAuthentication\Middleware\JwtCsrfDetectionMiddleware->process()
#12 /usr/share/php/passbolt/src/Middleware/GpgAuthHeadersMiddleware.php(40): Cake\Http\Runner->handle()
#13 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Http/Runner.php(73): App\Middleware\GpgAuthHeadersMiddleware->process()
#14 /usr/share/php/passbolt/plugins/PassboltCe/Locale/src/Middleware/LocaleMiddleware.php(47): Cake\Http\Runner->handle()
#15 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Http/Runner.php(73): Passbolt\Locale\Middleware\LocaleMiddleware->process()
#16 /usr/share/php/passbolt/plugins/PassboltCe/MultiFactorAuthentication/src/Middleware/InjectMfaFormMiddleware.php(66): Cake\Http\Runner->handle()
#17 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Http/Runner.php(73): Passbolt\MultiFactorAuthentication\Middleware\InjectMfaFormMiddleware->process()
#18 /usr/share/php/passbolt/plugins/PassboltCe/MultiFactorAuthentication/src/Middleware/MfaRequiredCheckMiddleware.php(82): Cake\Http\Runner->handle()
#19 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Http/Runner.php(73): Passbolt\MultiFactorAuthentication\Middleware\MfaRequiredCheckMiddleware->process()
#20 /usr/share/php/passbolt/vendor/cakephp/authentication/src/Middleware/AuthenticationMiddleware.php(124): Cake\Http\Runner->handle()
#21 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Http/Runner.php(73): Authentication\Middleware\AuthenticationMiddleware->process()
#22 /usr/share/php/passbolt/plugins/PassboltCe/JwtAuthentication/src/Middleware/JwtDestroySessionMiddleware.php(43): Cake\Http\Runner->handle()
#23 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Http/Runner.php(73): Passbolt\JwtAuthentication\Middleware\JwtDestroySessionMiddleware->process()
#24 /usr/share/php/passbolt/src/Middleware/SessionAuthPreventDeletedUsersMiddleware.php(46): Cake\Http\Runner->handle()
#25 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Http/Runner.php(73): App\Middleware\SessionAuthPreventDeletedUsersMiddleware->process()
#26 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Http/Middleware/BodyParserMiddleware.php(162): Cake\Http\Runner->handle()
#27 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Http/Runner.php(73): Cake\Http\Middleware\BodyParserMiddleware->process()
#28 /usr/share/php/passbolt/src/Middleware/SessionPreventExtensionMiddleware.php(66): Cake\Http\Runner->handle()
#29 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Http/Runner.php(73): App\Middleware\SessionPreventExtensionMiddleware->process()
#30 /usr/share/php/passbolt/plugins/PassboltCe/JwtAuthentication/src/Middleware/JwtRouteFilterMiddleware.php(47): Cake\Http\Runner->handle()
#31 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Http/Runner.php(73): Passbolt\JwtAuthentication\Middleware\JwtRouteFilterMiddleware->process()
#32 /usr/share/php/passbolt/plugins/PassboltCe/JwtAuthentication/src/Middleware/JwtAuthDetectionMiddleware.php(58): Cake\Http\Runner->handle()
#33 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Http/Runner.php(73): Passbolt\JwtAuthentication\Middleware\JwtAuthDetectionMiddleware->process()
#34 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Routing/Middleware/RoutingMiddleware.php(161): Cake\Http\Runner->handle()
#35 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Http/Runner.php(73): Cake\Routing\Middleware\RoutingMiddleware->process()
#36 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Routing/Middleware/AssetMiddleware.php(77): Cake\Http\Runner->handle()
#37 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Http/Runner.php(73): Cake\Routing\Middleware\AssetMiddleware->process()
#38 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Error/Middleware/ErrorHandlerMiddleware.php(126): Cake\Http\Runner->handle()
#39 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Http/Runner.php(73): Cake\Error\Middleware\ErrorHandlerMiddleware->process()
#40 /usr/share/php/passbolt/src/Middleware/ContentSecurityPolicyMiddleware.php(39): Cake\Http\Runner->handle()
#41 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Http/Runner.php(73): App\Middleware\ContentSecurityPolicyMiddleware->process()
#42 /usr/share/php/passbolt/src/Middleware/ContainerInjectorMiddleware.php(54): Cake\Http\Runner->handle()
#43 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Http/Runner.php(73): App\Middleware\ContainerInjectorMiddleware->process()
#44 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Http/Runner.php(58): Cake\Http\Runner->handle()
#45 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Http/Server.php(90): Cake\Http\Runner->run()
#46 /usr/share/php/passbolt/webroot/index.php(40): Cake\Http\Server->run()
#47 {main}
2023-01-30 13:38:26 error: [Authentication\Authenticator\UnauthenticatedException] Authentication is required to continue in /usr/share/php/passbolt/vendor/cakephp/authentication/src/Controller/Component/AuthenticationComponent.php on line 177
2023-01-30 13:38:56 error: [Authentication\Authenticator\UnauthenticatedException] Authentication is required to continue in /usr/share/php/passbolt/vendor/cakephp/authentication/src/Controller/Component/AuthenticationComponent.php on line 177
2023-01-30 13:39:14 error: [Authentication\Authenticator\UnauthenticatedException] Authentication is required to continue in /usr/share/php/passbolt/vendor/cakephp/authentication/src/Controller/Component/AuthenticationComponent.php on line 177
2023-01-30 13:54:03 error: [Authentication\Authenticator\UnauthenticatedException] Authentication is required to continue in /usr/share/php/passbolt/vendor/cakephp/authentication/src/Controller/Component/AuthenticationComponent.php on line 177
2023-01-30 13:55:11 error: [Cake\Http\Exception\InternalErrorException] The authentication failed. in /usr/share/php/passbolt/src/Controller/Auth/AuthLoginController.php on line 93
Request URL: /auth/login.json?api-version=v2
2023-01-30 13:55:11 error: The authentication failed.
2023-01-30 13:55:11 error: #0 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Controller/Controller.php(539): App\Controller\Auth\AuthLoginController->loginPost()
#47 {main}
2023-01-30 13:55:50 error: [Authentication\Authenticator\UnauthenticatedException] Authentication is required to continue in /usr/share/php/passbolt/vendor/cakephp/authentication/src/Controller/Component/AuthenticationComponent.php on line 177
2023-01-30 14:34:28 error: [Authentication\Authenticator\UnauthenticatedException] Authentication is required to continue in /usr/share/php/passbolt/vendor/cakephp/authentication/src/Controller/Component/AuthenticationComponent.php on line 177
2023-01-30 19:00:07 error: [Authentication\Authenticator\UnauthenticatedException] Authentication is required to continue in /usr/share/php/passbolt/vendor/cakephp/authentication/src/Controller/Component/AuthenticationComponent.php on line 177
Client IP: 10.0.110.9
2023-01-30 23:27:16 error: [Authentication\Authenticator\UnauthenticatedException] Authentication is required to continue in /usr/share/php/passbolt/vendor/cakephp/authentication/src/Controller/Component/AuthenticationComponent.php on line 177
2023-01-30 23:30:07 error: [Authentication\Authenticator\UnauthenticatedException] Authentication is required to continue in /usr/share/php/passbolt/vendor/cakephp/authentication/src/Controller/Component/AuthenticationComponent.php on line 177
2023-01-30 23:31:57 error: [Authentication\Authenticator\UnauthenticatedException] Authentication is required to continue in /usr/share/php/passbolt/vendor/cakephp/authentication/src/Controller/Component/AuthenticationComponent.php on line 177
2023-01-30 23:32:52 error: [Cake\Http\Exception\InternalErrorException] The authentication failed. in /usr/share/php/passbolt/src/Controller/Auth/AuthLoginController.php on line 93
2023-01-30 23:32:52 error: The authentication failed.
2023-01-30 23:32:52 error: #0 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Controller/Controller.php(539): App\Controller\Auth\AuthLoginController->loginPost()
@garrett
sorry my man:
all the information of the healthcare shell:
 [PASS] PHP version 7.4.33.
 [PASS] Full base url is set to http://10.0.110.10
 [PASS] 26 tables found
 [PASS] Using latest passbolt version (3.9.0).
 [HELP] Check App.fullBaseUrl url scheme in /etc/passbolt/passbolt.php.
 SMTP Settings
These errors need to be fixed.
hey @Dimmebag in addition to the HTTPS vs HTTP issue that @garrett mentioned could you run the status report and post the output?
For your set up this should be:
 sudo -H -u nginx bash -c “/usr/share/php/passbolt/bin/status-report”
This will include the healthcheck plus a couple other things which will give us a more full picture.
@garrett i dont use a SSL or certificate in this installation. Its a normal HTTP use without HTTPS.
What i can do, to resolve this issue in that message of healthcare???
@clayton
i runned that command and have all the results bellow:
Passbolt CE 3.9.0
Cakephp 4.3.7
Linux svr-rocky 4.18.0-425.3.1.el8.x86_64 #1 SMP Wed Nov 9 20:13:27 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
PHP 7.4.33 (cli) (built: Dec 19 2022 13:23:13) ( NTS )
mysql  Ver 15.1 Distrib 10.3.35-MariaDB, for Linux (x86_64) using readline 5.1
gpg (GnuPG) 2.2.20
libgcrypt 1.8.5
 SMTP Settings
And this too:
Data check shell
  [PASS] Can validate: 680/680
  [PASS] Can validate: 8/8
  [PASS] Can validate: 0/0
  [PASS] Can encrypt: 5/5
  [PASS] Pass validation service checks: 5/5
  [PASS] Entity data and armored key data matches: 5/5
  [PASS] Is not expired: 5/5
  [PASS] Is armored key format valid: 5/5
  [PASS] Can validate: 7/7
  [PASS] Can validate: 6/6
  [PASS] Can validate: 69/69
  [PASS] Can validate: 275/275
#47 {main}
2023-01-30 23:33:47 error: [Cake\Http\Exception\InternalErrorException] The authentication failed. in /usr/share/php/passbolt/src/Controller/Auth/AuthLoginController.php on line 93
2023-01-30 23:33:47 error: The authentication failed.
2023-01-30 23:33:47 error: #0 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Controller/Controller.php(539): App\Controller\Auth\AuthLoginController->loginPost()
#47 {main}
2023-01-31 10:38:17 error: [Authentication\Authenticator\UnauthenticatedException] Authentication is required to continue in /usr/share/php/passbolt/vendor/cakephp/authentication/src/Controller/Component/AuthenticationComponent.php on line 177
Client IP: 10.0.109.145
2023-01-31 11:12:09 error: [Authentication\Authenticator\UnauthenticatedException] Authentication is required to continue in /usr/share/php/passbolt/vendor/cakephp/authentication/src/Controller/Component/AuthenticationComponent.php on line 177
Hey @Dimmebag thanks for that! There should be another part with that output, if for some reason it wasn’t there can you run the following to produce it?
 sudo -H -u nginx bash -c “/ usr/share/php/passbolt/bin/cake passbolt cleanup”
The status report runs it with --dry-run but without it should just fix any issues present. Let me know if it changes anything by running that
@clayton
I tried, but nothing happened;
This message after command:
Cleanup shell (fix mode)
hey @Dimmebag the next thing to look at would be the browser extension logs. You can get those on Firefox by
  • going to: about:debugging#/runtime/this-firefox
  • locate Passbolt and click Inspect
  • A new tab for the console of the browser extension will appear.
  • Go to the network tab
  • try to reproduce the error
  • Export logs by clicking right on the logs and select “Save all As HAR”
@clayton
looks like the same error of json login. Followed your lead, and the results:
|id|cfd4d38d-9bcb-4ac6-bd0a-b816dd0bfee1|
|status|error|
|servertime|1675175857|
|action|4d2d5c43-a76a-5d4a-8f47-2b1f0268e3d6|
|message|Authentication is required to continue|
|url|/auth/is-authenticated.json|
|code|401|
|body||
|header||
|id|a9763c7e-726b-4626-85d0-972980a3ec63|
|status|success|
|servertime|1675175883|
|action|bef9f3ca-86ef-5c6a-9b38-320e03ceb5df|
|message|The operation was successful.|
|url|/settings.json?api-version=v2|
|code|200|
|body||
|app||
|url|http://10.0.110.10/|
|locale|en-UK|
|passbolt||
|legal||
|privacy_policy||
|url||
|terms||
|url|https://www.passbolt.com/terms|
|edition|ce|
|registration||
|public|false|
|plugins||
|jwtAuthentication||
|enabled|true|
|accountRecoveryRequestHelp||
|enabled|true|
|inFormIntegration||
|enabled|true|
|locale||
|options||
|0||
|locale|de-DE|
|label|Deutsch|
|1||
|locale|en-UK|
|label|English|
|2||
|locale|es-ES|
|label|Español|
|3||
|locale|fr-FR|
|label|Français|
|4||
|locale|ja-JP|
|label|日本語|
|5||
|locale|lt-LT|
|label|Lietuvių|
|6||
|locale|nl-NL|
|label|Nederlands|
|7||
|locale|pl-PL|
|label|Polski|
|8||
|locale|sv-SE|
|label|Svenska|
|rememberMe||
|options||
|300|5 minutes|
|900|15 minutes|
|1800|30 minutes|
|3600|1 hour|
|-1|until I log out|
Is this information, or you need the HAR file?
hey @Dimmebag actually a potentially better place to look will be in the browser console. Can you open that up by right clicking and selecting inspect, then picking the console tab and try to access the page again?
Let me know if there are any errors there
@clayton
I dont get it this point. I ill post a screen of all information displayed in the debbug mode of firefox:
We should probably check ngnix config too in case something changed there.
Another thought since this is Rocky, do you have SELinux enabled @Dimmebag ?
I think, this error its something about in Rocky Linux, because a installed a fresh version in a VM hardware and the same error appears without any data.
Installed in a CentOS7 and fresh install worked fine…
How i can test my dump of mysql in this new system? Copy and paste the keys in gpg folder works, or need more commands?
Sorry, for newbie questions!
Cheers and thank you both of you @clayton and @garrett
