I am trying to speed up interactions with the user interface.
Q2 - Who is impacted?
Everyone that wants to use the “Remember for 5 minutes”.
Usability is important. It’s very annoying to move your hand to the mouse just to click a checkbox before moving back to the keyboard.
Allow pressing Tab key to focus the “Remember for 5 minutes” checkbox which allows pressing space to “check” the checkbox before pressing Enter.
This has been suggested before: As a user on the login screen or master password dialog, my cursor should get auto focused on the password field · Issue #115 · passbolt/passbolt_api · GitHub
A related feature would be an option to have this box checked by default.
Q5. Community support
People can vote for this idea to show traction:
Must have: this is critical for me to have this -
Should have: this is important for me to have this -
Could have: this could be nice to have -
Won’t have: we should not schedule this (explain why)
0 voters
