I checked the server time and the timezone was incorrect, changed this but still got the same issue.
I pasted the cellphone log as well as the time and date from the server… allowing for human copy paste time they are 12 secs or so…
Checked and synced the server clock;
Mon Oct 31 07:20:14 EDT 2022
@passbolt:~# ntpstat
synchronised to NTP server (216.197.228.230) at stratum 2
time correct to within 26 ms
polling server every 64 s
I copied the end of the log to the top for clarity
07:20:03 Signing in
07:20:04 --> POST https://passbolt.tr/auth/jwt/login.json h2 (1621-byte body)
07:20:04 <-- 500 https://passbolt.tr/auth/jwt/login.json (144ms, unknown-length body)
07:20:04 Failure during sign in: An internal error occurred.
07:19:23 Checking biometry state
07:19:50 --> PUT https://passbolt.tr/mobile/transfers/fcfef86f-95ce-47d7-a82c-d3875bf58581/12e8b3d4-8dac-44d3-89e1-9e592ca7809e.json h2 (41-byte body)
07:19:50 <-- 200 https://passbolt.tr/mobile/transfers/fcfef86f-95ce-47d7-a82c-d3875bf58581/12e8b3d4-8dac-44d3-89e1-9e592ca7809e.json (73ms, unknown-length body)
07:19:51 --> PUT https://passbolt.tr/mobile/transfers/fcfef86f-95ce-47d7-a82c-d3875bf58581/12e8b3d4-8dac-44d3-89e1-9e592ca7809e.json h2 (41-byte body)
07:19:51 <-- 200 https://passbolt.tr/mobile/transfers/fcfef86f-95ce-47d7-a82c-d3875bf58581/12e8b3d4-8dac-44d3-89e1-9e592ca7809e.json (46ms, unknown-length body)
07:19:51 <-- 200 https://passbolt.tr/mobile/transfers/fcfef86f-95ce-47d7-a82c-d3875bf58581/12e8b3d4-8dac-44d3-89e1-9e592ca7809e.json (52ms, unknown-length body)
07:19:51 <-- 200 https://passbolt.tr/mobile/transfers/fcfef86f-95ce-47d7-a82c-d3875bf58581/12e8b3d4-8dac-44d3-89e1-9e592ca7809e.json (54ms, unknown-length body)
07:19:52 Saving private key.
07:19:52 --> PUT https://passbolt.tr/mobile/transfers/fcfef86f-95ce-47d7-a82c-d3875bf58581/12e8b3d4-8dac-44d3-89e1-9e592ca7809e.json?contain%5Buser.profile%5D=1 h2 (38-byte body)
07:19:52 <-- 200 https://passbolt.tr/mobile/transfers/fcfef86f-95ce-47d7-a82c-d3875bf58581/12e8b3d4-8dac-44d3-89e1-9e592ca7809e.json?contain%5Buser.profile%5D=1 (47ms, unknown-length body)
07:19:53 Checking biometry state
07:19:54 Received fill request
07:19:54 Visiting view node with id: -1 scheme + domain: null://null package: null content description: null autofill hints null hint: null html autocomplete attr: null important for autofill: 0 input type: 0
07:19:54 Visiting view node with id: 2131361857 scheme + domain: null://null package: com.passbolt.mobile.android content description: null autofill hints null hint: null html autocomplete attr: null important for autofill: 0 input type: 0
07:19:54 Visiting view node with id: 2131361873 scheme + domain: null://null package: com.passbolt.mobile.android content description: null autofill hints null hint: null html autocomplete attr: null important for autofill: 0 input type: 0
07:19:54 Visiting view node with id: 2131362114 scheme + domain: null://null package: com.passbolt.mobile.android content description: null autofill hints null hint: null html autocomplete attr: null important for autofill: 0 input type: 0
07:19:54 Visiting view node with id: 2131362531 scheme + domain: null://null package: com.passbolt.mobile.android content description: null autofill hints null hint: null html autocomplete attr: null important for autofill: 0 input type: 0
07:19:54 Visiting view node with id: -1 scheme + domain: null://null package: null content description: null autofill hints null hint: null html autocomplete attr: null important for autofill: 1 input type: 0
07:19:54 Visiting view node with id: 2131362282 scheme + domain: null://null package: com.passbolt.mobile.android content description: null autofill hints null hint: null html autocomplete attr: null important for autofill: 1 input type: 0
07:19:54 Visiting view node with id: 2131362063 scheme + domain: null://null package: com.passbolt.mobile.android content description: null autofill hints null hint: null html autocomplete attr: null important for autofill: 1 input type: 0
07:19:54 Visiting view node with id: 2131362040 scheme + domain: null://null package: com.passbolt.mobile.android content description: null autofill hints null hint: null html autocomplete attr: null important for autofill: 1 input type: 0
07:19:54 Visiting view node with id: 2131362328 scheme + domain: null://null package: com.passbolt.mobile.android content description: null autofill hints null hint: null html autocomplete attr: null important for autofill: 0 input type: 0
07:19:54 Visiting view node with id: 2131362528 scheme + domain: null://null package: com.passbolt.mobile.android content description: null autofill hints null hint: null html autocomplete attr: null important for autofill: 1 input type: 0
07:19:54 Visiting view node with id: 2131362510 scheme + domain: null://null package: com.passbolt.mobile.android content description: null autofill hints null hint: null html autocomplete attr: null important for autofill: 1 input type: 0
07:19:54 Visiting view node with id: 2131362170 scheme + domain: null://null package: com.passbolt.mobile.android content description: null autofill hints passwordAuto hint: null html autocomplete attr: null important for autofill: 1 input type: 129
07:19:54 Visiting view node with id: 2131362524 scheme + domain: null://null package: com.passbolt.mobile.android content description: null autofill hints null hint: null html autocomplete attr: null important for autofill: 1 input type: 0
07:19:54 Visiting view node with id: 2131361920 scheme + domain: null://null package: com.passbolt.mobile.android content description: null autofill hints null hint: null html autocomplete attr: null important for autofill: 1 input type: 0
07:19:54 Visiting view node with id: 2131361918 scheme + domain: null://null package: com.passbolt.mobile.android content description: null autofill hints null hint: null html autocomplete attr: null important for autofill: 1 input type: 0
07:19:54 Visiting view node with id: 2131362113 scheme + domain: null://null package: com.passbolt.mobile.android content description: null autofill hints null hint: null html autocomplete attr: null important for autofill: 1 input type: 0
07:19:54 Parsed domain:
07:19:54 Marking input as fillable.
Hint values: mail,username,mobile,number,name,mail,username,mobile,number,name,username
Structure hint: passwordAuto
Hint values: password,secret,passphrase,password,secret,passphrase,password
07:19:54 Showing authentication prompt
07:20:03 Passphrase cache cleared
07:20:03 Passphrase cached
07:20:03 Getting server pgp and rsa keys
07:20:03 --> GET https://passbolt.tr/auth/verify.json h2
07:20:03 <-- 200 https://passbolt.tr/auth/verify.json (42ms, unknown-length body)
07:20:03 --> GET https://passbolt.tr/auth/jwt/rsa.json h2
07:20:03 <-- 200 https://passbolt.tr/auth/jwt/rsa.json (33ms, unknown-length body)
07:20:03 Getting server pgp and rsa keys succeeded
07:20:03 Verifying server fingerprint
07:20:03 Server key fingerprint is valid
07:20:03 Preparing sign in challenge
07:20:03 Prepared sign in challenge
07:20:03 Signing in
