Provide your system information
System Information
– Server operating system name and version
LXC Container on Proxmox running an Ubuntu 24.04 template.
– Web server name and version
LXC - nginx version: nginx/1.24.0 (Ubuntu)
Reverse Proxy - NPMPlus - 2.12.3+0a85402
Cloudflare
Cloudflare → NPMP → LXC
– Database server name and version
mysql 8.0.42-0ubuntu0.24.04.2
– Php version
PHP 8.3.6 (cli) (built: Jul 14 2025 18:30:55) (NTS)
– Passbolt version
Can’t find version, assuming github… Somebody to love ([5.3.2] - 2025-07-16)
Healthcheck
root@passbolt:/opt# sudo su -s /bin/bash -c "/usr/share/php/passbolt/bin/cake passbolt healthcheck" www-data
If you want to have more information about the different checks, please take a look at the documentation: https://www.passbolt.com/docs/admin/server-maintenance/passbolt-api-status/
[INFO] Linux passbolt 6.8.12-4-pve #1 SMP PREEMPT_DYNAMIC PMX 6.8.12-4 (2024-11-06T15:04Z) x86_64 x86_64 x86_64 GNU/Linux
[PASS] PHP version 8.3.6.
[INFO] gpg (GnuPG) 2.4.4 / libgcrypt 1.10.3
[PASS] System clock is synchronized and NTP service is active.
[PASS] Full base url is set to https://pass.stefanocoding.me
SMTP settings
[PASS] Using latest passbolt version (5.3.2).
[PASS] 34 tables found.
Metadata
[PASS] No error found. Nice one, sparky!
Describe the problem thoroughly with as much details as possible so that people can reproduce the issues
Problem and details
– What steps did you take?
Passbolt is fully installed and working on both Windows, Web and extention. Encrypts and decrypts with the full vault.
– What happened?
Android is unable to sync, when checking the latest code, I am unable to setup due to a 403 error.
Logs
Device: Google Pixel 8
Android 16 (36)
Passbolt 2.1.1-38
17:09:56 --> PUT https://pass.stefanocoding.me/mobile/transfers/239e9d4f-3ead-48ae-907d-4b4463c06c71/33e57a85-18fa-4fea-ad65-7b62cec7546a.json h2 (41-byte body)
17:09:56 <-- 200 https://pass.stefanocoding.me/mobile/transfers/239e9d4f-3ead-48ae-907d-4b4463c06c71/33e57a85-18fa-4fea-ad65-7b62cec7546a.json (242ms, unknown-length body)
17:09:56 <-- 200 https://pass.stefanocoding.me/mobile/transfers/239e9d4f-3ead-48ae-907d-4b4463c06c71/33e57a85-18fa-4fea-ad65-7b62cec7546a.json (230ms, unknown-length body)
17:09:57 --> PUT https://pass.stefanocoding.me/mobile/transfers/239e9d4f-3ead-48ae-907d-4b4463c06c71/33e57a85-18fa-4fea-ad65-7b62cec7546a.json h2 (41-byte body)
17:09:57 <-- 200 https://pass.stefanocoding.me/mobile/transfers/239e9d4f-3ead-48ae-907d-4b4463c06c71/33e57a85-18fa-4fea-ad65-7b62cec7546a.json (149ms, unknown-length body)
17:09:58 <-- 200 https://pass.stefanocoding.me/mobile/transfers/239e9d4f-3ead-48ae-907d-4b4463c06c71/33e57a85-18fa-4fea-ad65-7b62cec7546a.json (114ms, unknown-length body)
17:09:58 Saving private key.
17:09:58 --> PUT https://pass.stefanocoding.me/mobile/transfers/239e9d4f-3ead-48ae-907d-4b4463c06c71/33e57a85-18fa-4fea-ad65-7b62cec7546a.json?contain%5Buser.profile%5D=1 h2 (38-byte body)
17:09:58 <-- 403 https://pass.stefanocoding.me/mobile/transfers/239e9d4f-3ead-48ae-907d-4b4463c06c71/33e57a85-18fa-4fea-ad65-7b62cec7546a.json?contain%5Buser.profile%5D=1 (40ms, unknown-length body)
17:09:58 retrofit2.HttpException: HTTP 403
at retrofit2.KotlinExtensions$await$2$2.onResponse(SourceFile:53)
at retrofit2.OkHttpCall$1.onResponse(SourceFile:164)
at okhttp3.internal.connection.RealCall$AsyncCall.run(SourceFile:519)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1156)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:651)
at java.lang.Thread.run(Thread.java:1119)
17:09:58 Encountered a non-standard backend error response
17:09:58 There was an error during checking if MFA is required
java.lang.NullPointerException: null cannot be cast to non-null type kotlin.collections.Map<kotlin.String, kotlin.collections.List<kotlin.String>>
at com.passbolt.mobile.android.core.networking.ErrorHeaderMapper.checkMfaRequired(SourceFile:71)
at com.passbolt.mobile.android.core.networking.ResponseHandler.checkIfMfaRequired(SourceFile:76)
at com.passbolt.mobile.android.core.networking.ResponseHandler.handleException(SourceFile:50)
at com.passbolt.mobile.android.passboltapi.registration.MobileTransferRepository.turnPage(SourceFile:97)
at com.passbolt.mobile.android.passboltapi.registration.MobileTransferRepository$turnPage$1.invokeSuspend(Unknown Source:16)
at kotlin.coroutines.jvm.internal.BaseContinuationImpl.resumeWith(SourceFile:33)
at kotlinx.coroutines.DispatchedTask.run(SourceFile:102)
at kotlinx.coroutines.internal.LimitedDispatcher$Worker.run(SourceFile:111)
at kotlinx.coroutines.scheduling.TaskImpl.run(SourceFile:99)
at kotlinx.coroutines.scheduling.CoroutineScheduler.runSafely(SourceFile:585)
at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.executeTask(SourceFile:802)
at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.runWorker(SourceFile:706)
at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.run(SourceFile:693)
17:09:58 There was an error during transfer update
17:10:01 Checking biometry state
17:10:02 Received fill request
17:10:02 Visiting view node with id: -1 scheme + domain: null://null package: null content description: null autofill hints null hint: null html autocomplete attr: null important for autofill: 0 input type: 0
17:10:02 Visiting view node with id: 2131361871 scheme + domain: null://null package: com.passbolt.mobile.android content description: null autofill hints null hint: null html autocomplete attr: null important for autofill: 0 input type: 0
17:10:02 Visiting view node with id: 2131361892 scheme + domain: null://null package: com.passbolt.mobile.android content description: null autofill hints null hint: null html autocomplete attr: null important for autofill: 0 input type: 0
17:10:02 Visiting view node with id: 2131362208 scheme + domain: null://null package: com.passbolt.mobile.android content description: null autofill hints null hint: null html autocomplete attr: null important for autofill: 0 input type: 0
17:10:02 Visiting view node with id: 2131362731 scheme + domain: null://null package: com.passbolt.mobile.android content description: null autofill hints null hint: null html autocomplete attr: null important for autofill: 0 input type: 0
17:10:02 Visiting view node with id: -1 scheme + domain: null://null package: null content description: null autofill hints null hint: null html autocomplete attr: null important for autofill: 1 input type: 0
17:10:02 Visiting view node with id: 2131362417 scheme + domain: null://null package: com.passbolt.mobile.android content description: null autofill hints null hint: null html autocomplete attr: null important for autofill: 1 input type: 0
17:10:02 Visiting view node with id: 2131362135 scheme + domain: null://null package: com.passbolt.mobile.android content description: null autofill hints null hint: null html autocomplete attr: null important for autofill: 1 input type: 0
17:10:02 Visiting view node with id: 2131362112 scheme + domain: null://null package: com.passbolt.mobile.android content description: null autofill hints null hint: null html autocomplete attr: null important for autofill: 1 input type: 0
17:10:02 Visiting view node with id: 2131362488 scheme + domain: null://null package: com.passbolt.mobile.android content description: null autofill hints null hint: null html autocomplete attr: null important for autofill: 0 input type: 0
17:10:02 Visiting view node with id: 2131362728 scheme + domain: null://null package: com.passbolt.mobile.android content description: null autofill hints null hint: null html autocomplete attr: null important for autofill: 1 input type: 0
17:10:02 Visiting view node with id: 2131362708 scheme + domain: null://null package: com.passbolt.mobile.android content description: null autofill hints null hint: null html autocomplete attr: null important for autofill: 1 input type: 0
17:10:02 Visiting view node with id: 2131362275 scheme + domain: null://null package: com.passbolt.mobile.android content description: null autofill hints passwordAuto hint: null html autocomplete attr: null important for autofill: 1 input type: 129
17:10:02 Visiting view node with id: 2131362722 scheme + domain: null://null package: com.passbolt.mobile.android content description: null autofill hints null hint: null html autocomplete attr: null important for autofill: 1 input type: 0
17:10:02 Visiting view node with id: 2131361968 scheme + domain: null://null package: com.passbolt.mobile.android content description: null autofill hints null hint: null html autocomplete attr: null important for autofill: 1 input type: 0
17:10:02 Visiting view node with id: 2131361966 scheme + domain: null://null package: com.passbolt.mobile.android content description: null autofill hints null hint: null html autocomplete attr: null important for autofill: 1 input type: 0
17:10:02 Visiting view node with id: 2131362207 scheme + domain: null://null package: com.passbolt.mobile.android content description: null autofill hints null hint: null html autocomplete attr: null important for autofill: 1 input type: 0
17:10:02 Parsed domain:
17:10:02 Marking input as fillable.
Hint values: mail,username,mobile,number,name,mail,username,mobile,number,name,username
Structure hint: passwordAuto
Hint values: password,secret,passphrase,password,secret,passphrase,password
17:10:02 Showing authentication prompt
17:10:07 Passphrase cache cleared
17:10:07 Passphrase cached
17:10:07 Getting server pgp and rsa keys
17:10:07 --> GET https://pass.stefanocoding.me/auth/verify.json h2
17:10:07 <-- 200 https://pass.stefanocoding.me/auth/verify.json (192ms, unknown-length body)
17:10:07 --> GET https://pass.stefanocoding.me/auth/jwt/rsa.json h2
17:10:08 <-- 200 https://pass.stefanocoding.me/auth/jwt/rsa.json (117ms, unknown-length body)
17:10:08 Getting server pgp and rsa keys succeeded
17:10:08 Checking if time adjustment is needed
17:10:08 Local time sync needed. Adjusted: -1
17:10:08 Verifying server fingerprint
17:10:08 Server key fingerprint is valid
17:10:08 Preparing sign in challenge
17:10:08 Prepared sign in challenge
17:10:08 Signing in
17:10:08 --> POST https://pass.stefanocoding.me/auth/jwt/login.json h2 (1699-byte body)
17:10:08 <-- 403 https://pass.stefanocoding.me/auth/jwt/login.json (25ms, unknown-length body)
17:10:08 Encountered a non-standard backend error response
17:10:08 There was an error during checking if MFA is required
at com.passbolt.mobile.android.passboltapi.auth.AuthRepository.signIn(SourceFile:114)
at com.passbolt.mobile.android.passboltapi.auth.AuthRepository$signIn$1.invokeSuspend(Unknown Source:12)
at kotlinx.coroutines.DispatchedTask.run(SourceFile:104)
at android.os.Handler.handleCallback(Handler.java:995)
at android.os.Handler.dispatchMessage(Handler.java:103)
at android.os.Looper.loopOnce(Looper.java:248)
at android.os.Looper.loop(Looper.java:338)
at android.app.ActivityThread.main(ActivityThread.java:9067)
at java.lang.reflect.Method.invoke(Native Method)
at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:593)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:932)
17:10:08 Failure during sign in: Something went wrong!
– What did you expect instead?
Being able to login to passbolt on my phone.
Other issues with similair logs
https://community.passbolt.com/t/cannot-scan-qr-code-on-android/8754
https://community.passbolt.com/t/android-qr-code-error-during-transport-update/8446
