Hi
I have a perculiar problem… every time I enable my .conf in either /conf.d or /vhost.d all webservers on the hosts stops responding, including the ones configured at /srv/www/htdocs.
In fact… I’m not sure this is a problem relating to Passbolt - as I’m at the same time started experimenting with LXC on ProxMox.
My setup:
- SLES 15 SP3 running as LXC on ProxMox
- Apache2 2.4.43 with PHP 7.4.6
Installation passed on without any problems, but I did have some problem finding a conf file for apache - but ended up using an adapted version of the on from: Install and Setup Passbolt Password Manager on Ubuntu 20.04 - kifarunix.com
Best regards
/Adder
Hi @BlackAdderDK
and welcome to this forum
If all configured hosts stop responding when you enable passbolt .conf file, I guess there is some bad config in your Passbolt virtualhost file.
With Apache, there is a command to check virtualhost configuration files. Launch it as root user and you will see what is wrong:
# apache2ctl configtest
Let us know if this help you to find typos.
Oh, I forgot to say, you still have to deal with the installation from source on SLES for now, but a RPM package is on the road
Hi _jc
Guess I wasn’t clear enough - I did install Passbolt form sourcefiles, without any hickups.
Apache is running fine:
MyWebSrv03:~ # apache2ctl configtest
Syntax OK
And if I use eg. 127.0.0.1:80/443 instead of *:80/443 (or 0.0.0.0:80/443), then all the other webhosts starts answering…
Best
'Adder
I didn’t understood your problem, it is more clear now. Our recommendation is to install passbolt on a fresh vanilla server following this documentation: Passbolt Help | Install passbolt API from source
If you still want to use apache2 on your server with other vhosts configured on it, maybe should you have a look at the Apache vhost configuration ? I see in the documentation you followed than Passbolt is set as the default one.
How other virtualhosts are set on your server ? Can you share here your Passbolt virtualhost configuration file ?
Thanks and regards,
Hi
Just as a follow up - I noticed there was a newer version… removed the old one, reinstalled from source - everything works perfectly now… thanks
Best regards
'Adder
