we are using Passbolt in combination with Rocket Remotedesktop formerly ASG .
My question is it is possilbe to use the mfa totp with the API or especially with asg?
Thx
Thx
Hello @D3n , welcome to our community ![]()
Could you be a little more precise? If you could explain what you are trying to achieve, what you are seeing and what is happening instead it’d be great. Personally, I do not know Rocket Remote Desktop so it’s hard to understand what you are trying to do here or how is it related to MFA.
Thanks ![]()
ASG is a remotedesktop Suite where you can Store RDP Connections, and it has a Passbolt Integration through the API, so is it Possilbe to Secure the API with an MFA?
