Hello All,
I have login problem after new installation CE version of passbolt. I added screenshot of errors. Are there anybody know reasons of this issues?
Hello All,
Hey @dincos welcome to the forum!
This could be a couple different things, generally we’ll see this issue if there is a time sync issue of if SELinux is blocking it.
What distribution did you install on? Also, did you set up NTP?
Hello @clayton ,
Firstly, thank you so much for your answer. I did install it on AlmaLinux OS. And NTP server setting keeping default settings. I added timedatectl command output.
Is there any fix I might be able to make?
Hello @dincos, since NTP is active and you mentioned AlmaLinux, it could be related to SELinux.
You can try to run:
setsebool -P httpd_use_gpg=on
setsebool -P gpg_web_anon_write=on
semanage permissive -a gpg_web_t
Hello @antony,
Thank you so much for help. That’s worked.
