I am trying to send mails via outlook365, which fails with:
docker-compose exec passbolt su -m -c "/usr/share/php/passbolt/bin/cake \
passbolt send_test_email --recipient=test@example.org --verbose" -s /bin/sh www-data
Debug email shell
Email configuration
Host: smtp.office365.com
Port: 587
Username: test123@example.org
Password: *********
TLS: true
Sending email from: Passbolt <test123@example.org>
Sending email to: test@example.org
Trace
[220] AS9PR06CA0023.outlook.office365.com Microsoft ESMTP MAIL Service ready at Wed, 16 Mar 2022 11:15:51 +0000
> EHLO localhost
[250] AS9PR06CA0023.outlook.office365.com Hello [1.2.3.4]
[250] SIZE 157286400
[250] PIPELINING
[250] DSN
[250] ENHANCEDSTATUSCODES
[250] STARTTLS
[250] 8BITMIME
[250] BINARYMIME
[250] CHUNKING
[250] SMTPUTF8
> STARTTLS
[220] 2.0.0 SMTP server ready
> EHLO localhost
[250] PIPELINING
[250] DSN
[250] AUTH LOGIN XOAUTH2
[250] 8BITMIME
[250] BINARYMIME
[250] CHUNKING
[250] SMTPUTF8
> AUTH PLAIN xxx*****
[504] 5.7.4 Unrecognized authentication type [AS9PR06CA0023.eurprd06.prod.outlook.com]
> AUTH LOGIN
[334] xxx
[334] xxx
Error: SMTP server did not accept the password.
This is the docker-compose.yml:
version: '3.7'
db:
image: mariadb:10.7.1
restart: unless-stopped
MYSQL_DATABASE: "passbolt"
MYSQL_USER: "passbolt"
MYSQL_PASSWORD: "xxx"
image: passbolt/passbolt:3.5.0-ce
tty: true
depends_on:
- db
APP_FULL_BASE_URL: https://passbolt.example.org
DATASOURCES_DEFAULT_PASSWORD: "xxx"
EMAIL_DEFAULT_FROM: "test123@example.org"
EMAIL_TRANSPORT_DEFAULT_HOST: "smtp.office365.com"
EMAIL_TRANSPORT_DEFAULT_USERNAME: "test123@example.org"
EMAIL_TRANSPORT_DEFAULT_PASSWORD: "xxx"
networks:
- traefik_web
- default
database_volume:
driver: local
gpg_volume:
driver: local
jwt_volume:
driver: local
networks:
traefik_web:
external: true
The credentials are working fine on a GitLab-server running with docker, so I don’t see the problem here.
