and as opposed to the tutorial the link at the end of the installation sends me to the nginx site
instead of the passbolt configuration page
the page looks similar to this:
Welcome to nginx!
If you see this page, the nginx web server is successfully installed and working. Further configuration is required.
For online documentation and support please refer to nginx . org
Commercial support is available at nginx . com
Thank you for using nginx.
Please, do you have any idea how to fix this?
I need to have access from remote host. It should open Passbolt webapage, not NGINX page.
i also saw another user have the same problem but i didnt see a reply
Thank you in advance.
Which hostname are you using to access the passbolt install? Is this hostname you are using the same you introduced during the setup process?
In order to check the hostname you introduced on the setup you can check on /etc/nginx/conf.d/passbolt.conf and look for the line that contains āserver_nameā
i used the same hostname yes, but i also tried with ip but the result was the same
and in the file ā/etc/nginx/conf.d/passbolt.confā
the āserver_nameā is shown as SERVER_NAME
I added this bug https://github.com/passbolt/passbolt_install_scripts/issues/10
If you have any information on the context of your setup like the steps to reproduce (special characters on the hostname, etc) feel free to add them on the issue I created.
there was no special steps to encounter the issue i was following along with the guide and ran into the issue.
I hope itās not just a mistake on my end
