Hello everybody!
I have a problem so I think someone here can help me for sure!
I have followed tutorial on:
https://help.passbolt.com/hosting/install/ce/ubuntu-18-04-bionic-beaver.html
I have Ubuntu server hosted on virtual machine Ubuntu 18.04.2 LTS with GUI.
I have installed Passbolt as per instructions from your website and everything went fine. I can access Passbolt and login to the application from the host, locally. (hostname is passbolt.local)
When i try to login from remote PC from the same network, I type IP address of the server, but i receive notification:
Welcome to nginx!
If you see this page, the nginx web server is successfully installed and working. Further configuration is required.
For online documentation and support please refer to nginx . org
Commercial support is available at nginx . com
Thank you for using nginx.
I think it is something with the configuration of nginx because it doesn’t redirect me to the Passbolt app, it stays at root?
Please, do yo have any idea how to fix this?
I need to have access from remote host. It should open Passbolt webapage, not NGINX page.
Thank you in advance.
