Hi guys,
I have installed Passbolt 2 on Ubuntu 16.04 Xenial following Debian 9 instructions.
At the end I configured my plugin and after authentication i got this issue:
“Could not verify server key. There was an error during authentication. Enable debug mode for more information”
See the screenshot:
Apache and Passbolt logs dont show anything.
I used gpgv1 without passphrase. Fingerprint in passpbolt.php passed OK.
However apache uses php7.0 modules instead of php.
Here is a list:
ii dh-php 0.10 all debhelper add-on to handle PHP PECL extensions
ii libapache2-mod-php7.0 7.0.32-0ubuntu0.16.04.1 amd64 server-side, HTML-embedded scripting language (Apache 2 module)
ii php-cli 1:7.0+35ubuntu6.1 all command-line interpreter for the PHP scripting language (default)
ii php-cli-prompt 1.0.1+dfsg-1build1 all tiny helper prompting for user input
ii php-common 1:35ubuntu6.1 all Common files for PHP packages
ii php-composer-semver 1.2.0-1build1 all Semver library that offers utilities, version constraint parsing and
ii php-composer-spdx-licenses 1.1.2-1build1 all SPDX licenses list and validation library
ii php-gnupg 1.3.6-1ubuntu1 amd64 wrapper around the gpgme library
ii php-json-schema 1.6.1-1build1 all implementation of JSON schema
ii php-pear 1:1.10.1+submodules+notgz-6 all PEAR Base System
ii php-symfony-console 2.7.10-0ubuntu2 all run tasks from the command line
ii php-symfony-filesystem 2.7.10-0ubuntu2 all basic filesystem utilities
ii php-symfony-finder 2.7.10-0ubuntu2 all find files and directories
ii php-symfony-process 2.7.10-0ubuntu2 all execute commands in sub-processes
ii php7.0 7.0.32-0ubuntu0.16.04.1 all server-side, HTML-embedded scripting language (metapackage)
ii php7.0-cli 7.0.32-0ubuntu0.16.04.1 amd64 command-line interpreter for the PHP scripting language
ii php7.0-common 7.0.32-0ubuntu0.16.04.1 amd64 documentation, examples and common module for PHP
ii php7.0-curl 7.0.32-0ubuntu0.16.04.1 amd64 CURL module for PHP
ii php7.0-dev 7.0.32-0ubuntu0.16.04.1 amd64 Files for PHP7.0 module development
ii php7.0-gd 7.0.32-0ubuntu0.16.04.1 amd64 GD module for PHP
ii php7.0-intl 7.0.32-0ubuntu0.16.04.1 amd64 Internationalisation module for PHP
ii php7.0-json 7.0.32-0ubuntu0.16.04.1 amd64 JSON module for PHP
ii php7.0-mbstring 7.0.32-0ubuntu0.16.04.1 amd64 MBSTRING module for PHP
ii php7.0-mysql 7.0.32-0ubuntu0.16.04.1 amd64 MySQL module for PHP
ii php7.0-opcache 7.0.32-0ubuntu0.16.04.1 amd64 Zend OpCache module for PHP
ii php7.0-readline 7.0.32-0ubuntu0.16.04.1 amd64 readline module for PHP
ii php7.0-xml 7.0.32-0ubuntu0.16.04.1 amd64 DOM, SimpleXML, WDDX, XML, and XSL module for PHP
ii pkg-php-tools
As you can see there is only php-gnupg installed instead of php7.0-gnupg.
Do you think this might be the issue?
I could not manage to get php7.0-gnupg installed.
Thank you
Mario
