I already write an issue on the github but i don’t know where it’s better to post ?
I have this error on my playbook when I use the lookup ansible anatomicjc.passbolt :
TASK [Passbolt lookup plugin / fetch one] ********************************************************************************************************************
fatal: [server -> localhost]: FAILED! =>
msg: 'An unhandled exception occurred while running the lookup plugin ''anatomicjc.passbolt.passbolt''. Error was a <class ''json.decoder.JSONDecodeError''>, original message: Expecting value: line 1 column 1 (char 0). Expecting value: line 1 column 1 (char 0)'
Here is my code :
- hosts: all
gather_facts: false
PASSBOLT_BASE_URL: "http://vault.test.fr"
PASSBOLT_VERIFY: false
PASSBOLT_CREATE_NEW_RESOURCE: true
PASSBOLT_PRIVATE_KEY: "mygpgkey"
PASSBOLT_PASSPHRASE: "foobar"
tasks:
- name: "Passbolt lookup plugin / fetch one"
delegate_to: localhost
become: false
ansible.builtin.debug:
var: item
loop:
- "{{ lookup('anatomicjc.passbolt.passbolt', 'Test') }}"
changed_when: true
become: false
var: lookup(anatomicjc.passbolt.passbolt, 'test2', paswword='test1324*')
changed_when: true
I don’t know where is my mistake ? I think i configure everything like it needs to be.
Plugin version :
anatomicjc.passbolt 0.0.14
passbolt 1.24
py-passbolt 0.0.18
I have a Self Signed Certificate but i don’t think it’s coming from this.
Regards,
I change my playbook to use the ansible-vault, i think the problem comes from the last newline of the gpg key after the sed command.
Now I have this error :
msg: 'An unhandled exception occurred while running the lookup plugin ''anatomicjc.passbolt.passbolt''. Error was a <class ''ValueError''>, original message: Expected: ASCII-armored PGP data. Expected: ASCII-armored PGP data'
i don’t know what is the problem
I can confirm that my creds are good, i can use the passbolt CLI :
passbolt configure --serverAddress http://vault.test.fr --userPassword 'PASSWORD' --userPrivateKeyFile passbolt_private.asc
passbolt list resource
ID | FolderParentID | Name | Username | URI
b7209b02-d545-4045-91ef-5e268401b168 | | Test | Test | http://example.fr
passbolt get resource --id b7209b02-d545-4045-91ef-5e268401b168
FolderParentID:
Username: Test
URI: http://example.fr
Password: Test1234*
Description: test
Hi @RomyxBaps
Regarding the PASSBOLT_PRIVATE_KEY variable, did you put your gpg key in oneline format ?
sed -z 's/\n/\\n/g' your_private_key.asc
Reference: Ansible Galaxy
Hello @AnatomicJC ,
Thank you for your reply !
Yes i did the command for my private_key that i get from the WebUI on my user profile.
Here is the debug of the PASSBOLT_PASSPHRASE and PASSBOLT_PRIVATE_KEY :
TASK [DEBUG ENV PASSPHRASE] **************************************************************************************************************************************************************************************************************************************************************************************************
changed: [server -> localhost] =>
ansible_env.PASSBOLT_PASSPHRASE: Test1234*
TASK [DEBUG ENV PRIVATEKEY] **************************************************************************************************************************************************************************************************************************************************************************************************
ansible_env.PASSBOLT_PRIVATE_KEY: '-----BEGIN PGP PRIVATE KEY BLOCK-----\n\nxcTGBGaRnUIBDADz47BGZak6YWdJonVg/8VXpL4nGwDeTneEjP2YndRCvwVm\nE/msqrnvvf8G+NvBTeS8EfFXg7924lqlcP4w7ZnxPAnPZftZmZCqjGcSEFkH\nG5m7m4biJq.....
CqV9re0EKWdLkovgfiMnw9bjhxUzIUjsiMslAb+2+b\nuo6pyC0rmLetUH4wJW8fyFc2/tqx/UNq9xrcmG8rCUhm8koO5/bIjA2cw1LV\n1cT4GElesiJvQRMjIbKx/oDvPhWatJJEFBOqZu7E0Q==\n=mC+7\n-----END
PGP PRIVATE KEY BLOCK-----\n'
TASK [Passbolt lookup plugin / fetch one] ************************************************************************************************************************************************************************************************************************************************************************************
PLAY RECAP *******************************************************************************************************************************************************************************************************************************************************************************************************************
server : ok=9 changed=8 unreachable=0 failed=1 skipped=0 rescued=0 ignored=0
Maybe it’s not good on the gpgkey ?
Do you really have the five dots and the return line for PGP PRIVATE KEY BLOCK-----\n'
In my example playbook, I replaced the first task with this one to display ada_private_key_vault
content:
- name: "Password from ansible vault"
debug:
var: ada_private_key_vault
Here is the output:
TASK [Password from ansible vault] *****************************************************************************************************************************************************************************************************************************************************
Thursday 08 August 2024 12:27:40 +0000 (0:00:00.021) 0:00:00.021 *******
ok: [local1] => {
"ada_private_key_vault": "-----BEGIN PGP PRIVATE KEY BLOCK-----\n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\nv04k4WsQApMcVvv2Ja5Wo/+EjvSjuw==\n=4tPN\n-----END PGP PRIVATE KEY BLOCK-----\n"
there is only one line.
I dont have the five dots it’s to avoid to display a lot of line.
BUT i really have the return line for PGP PRIVATE KEY BLOCK-----\n'
I don’t really know why because i test it multiple times with every time a re-download of the passbolt_private.asc from my user in passbotl’s webui.
It is not a problem, you can try to put the END PGP PRIVATE KEY BLOCK on the same line:
Same error…
Here is all my private key (no worries it’s a lab) from a file after the command sed :
-----BEGIN PGP PRIVATE KEY BLOCK-----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\n1cT4GElesiJvQRMjIbKx/oDvPhWatJJEFBOqZu7E0Q==\n=mC+7\n-----END PGP PRIVATE KEY BLOCK-----
here is the result from my playbook :
ansible_env.PASSBOLT_PRIVATE_KEY: '-----BEGIN PGP PRIVATE KEY BLOCK-----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\n1cT4GElesiJvQRMjIbKx/oDvPhWatJJEFBOqZu7E0Q==\n=mC+7\n-----END
PGP PRIVATE KEY BLOCK-----'
Here is my playbook:
# export OBJC_DISABLE_INITIALIZE_FORK_SAFETY=YES
- hosts: all
gather_facts: no
PASSBOLT_BASE_URL: "http://passbolt"
#PASSBOLT_GPG_LIBRARY: "gnupg"
#PASSBOLT_FINGERPRINT: "064DE03152856A227FEFB0AD56BB3FB586945488"
PASSBOLT_PRIVATE_KEY: "{{ ada_private_key_vault }}"
PASSBOLT_PASSPHRASE: "{{ ada_passphrase_vault }}"
PASSBOLT_CREATE_NEW_RESOURCE: "true"
PASSBOLT_NEW_RESOURCE_PASSWORD_LENGTH: 20
PASSBOLT_NEW_RESOURCE_PASSWORD_SPECIAL_CHARS: "true"
vars:
passbolt: 'anatomicjc.passbolt.passbolt'
passbolt_inventory: 'anatomicjc.passbolt.passbolt_inventory'
aws:
access_key: "{{ lookup(passbolt, 'AWS').password }}"
secret_key: "{{ lookup(passbolt, 'AWS').description }}"
# To understand python regex syntax: https://docs.python.org/3/howto/regex.html
passbolt_check_naming_only_alphanumerics: '^\w*$'
passbolt_check_naming_alphanumerics_separated_with_spaces: '^\w*\s*\w*$'
tasks:
debug:
become: false
var: item
loop:
changed_when: true
Here is my inventory/group_vars/all/vault.yml
ansible_vault_protected: !vault |
$ANSIBLE_VAULT;1.1;AES256
61363037313764343735346263316433346330613930623265643533613835336361316561376261
3564396539623162343064636438313030306262306637380a386636313730323139306139326430
66386565386566666662346162373139366633306537643730346333396261376438643433653064
6264643035353239360a643736396264323432383965653235343431653837643136353536646462
65313865396637646464636234373333313632303962323637346236643364353365363333333765
39363165393166313265666364316363363536356165353332383132306564396533313663643733
383438626661386263626462356239626233
ada_private_key_vault: "-----BEGIN PGP PRIVATE KEY BLOCK-----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\n1cT4GElesiJvQRMjIbKx/oDvPhWatJJEFBOqZu7E0Q==\n=mC+7\n-----END PGP PRIVATE KEY BLOCK-----"
ada_passphrase_vault: Test1234*
Here is my output
{'body': None,
'header': {'action': 'a3c19ad2-8920-5395-86d0-8567cb34f382',
'code': 400,
'id': '2b343ebe-3d81-4293-9ced-a200974307fd',
'message': 'There is no user associated with this key. User not '
'found.',
'servertime': 1723139576,
'status': 'error',
'url': '/auth/login.json'}}
I used the docker-compose file from GitHub - passbolt/lab-passbolt-ansible-poc
I’ll test that.
Also, is there a specific configuration to do in the file config/passbolt.php for the gpg use case ?
Oh !! It’s working like a charm !
I don’t know why with the sed
command it’s nor working… But with the gpg key copy/paste after the command sed
inside a var in my playbook it’s ok.
changed: [rmx-vault-01.rmx.romyx.fr -> localhost] =>
ansible_env.PASSBOLT_PRIVATE_KEY: |-
=mC+7
lookup('anatomicjc.passbolt.passbolt', 'Test'):
created: '2024-08-03T13:29:27+00:00'
deleted: false
description: test
folder_parent_id: null
modified: '2024-08-03T13:29:27+00:00'
modified_by: e82b8c37-afe7-49f9-8dd6-6a4e11a36d22
password: Test1234*
personal: true
resource_type_id: 669f8c64-242a-59fb-92fc-81f660975fd3
uri: http://example.fr
username: Test
TASK [Passbolt lookup plugin create password] ****************************************************************************************************************
lookup(passbolt, 'test2', username='test2', uri='https://example.com', password='test1324*'):
created: '2024-08-09T17:41:12+00:00'
deleted: false
description: Ansible Generated
modified: '2024-08-09T17:41:12+00:00'
password: test1324*
personal: true
resource_type_id: a28a04cd-6f53-518a-967c-9963bf9cec51
uri: https://example.com
username: test2
As you can see, the GPG Key is the same as before in the debug but working now
I have a question, is it possible to create a password inside a folder, apparently yes but only with de folder id ?
Is it possible to delete a password ? I saw in passbolt.py a line "deleted": resource.get("deleted", ""),
in the function _format_result
but i tried with lookup(passbolt, 'test3', deleted=True, username='test2mariadb', uri='https://example.com', password='test1324*', folder_parent_id='d5c459af-66fb-428b-985e-71926c50a95d')
Also can we use a simple var and not environment variable ?
