Error scanning a QR code on Android
Hello.
After installing Passbolt using docker-compose, there was a problem when scanning a QR code.
When scanning, an error pops up: “There was an error during transfer update”, below app logs from phone:
Logs from Android
Device: Xiaomi Mi 9T Pro
Android 11 (30)
Passbolt 1.7.1-9
00:35:11 javax.net.ssl.SSLHandshakeException: java.security.cert.CertPathValidatorException: Trust anchor for certification path not found.
at com.android.org.conscrypt.SSLUtils.toSSLHandshakeException(SSLUtils.java:362)
at com.android.org.conscrypt.ConscryptEngine.convertException(ConscryptEngine.java:1134)
at com.android.org.conscrypt.ConscryptEngine.readPlaintextData(ConscryptEngine.java:1089)
at com.android.org.conscrypt.ConscryptEngine.unwrap(ConscryptEngine.java:876)
at com.android.org.conscrypt.ConscryptEngine.unwrap(ConscryptEngine.java:747)
at com.android.org.conscrypt.ConscryptEngine.unwrap(ConscryptEngine.java:712)
at com.android.org.conscrypt.ConscryptEngineSocket$SSLInputStream.processDataFromSocket(ConscryptEngineSocket.java:849)
at com.android.org.conscrypt.ConscryptEngineSocket$SSLInputStream.access$100(ConscryptEngineSocket.java:722)
at com.android.org.conscrypt.ConscryptEngineSocket.doHandshake(ConscryptEngineSocket.java:238)
at com.android.org.conscrypt.ConscryptEngineSocket.startHandshake(ConscryptEngineSocket.java:217)
at okhttp3.internal.connection.RealConnection.connectTls(SourceFile:367)
at okhttp3.internal.connection.RealConnection.establishProtocol(SourceFile:325)
at okhttp3.internal.connection.RealConnection.connect(SourceFile:197)
at okhttp3.internal.connection.ExchangeFinder.findConnection(SourceFile:249)
at okhttp3.internal.connection.ExchangeFinder.findHealthyConnection(SourceFile:108)
at okhttp3.internal.connection.ExchangeFinder.find(SourceFile:76)
at okhttp3.internal.connection.RealCall.initExchange$okhttp(SourceFile:245)
at okhttp3.internal.connection.ConnectInterceptor.intercept(SourceFile:32)
at okhttp3.internal.http.RealInterceptorChain.proceed(SourceFile:100)
at okhttp3.internal.cache.CacheInterceptor.intercept(SourceFile:96)
at okhttp3.internal.http.BridgeInterceptor.intercept(SourceFile:83)
at okhttp3.internal.http.RetryAndFollowUpInterceptor.intercept(SourceFile:76)
at com.passbolt.mobile.android.core.networking.interceptor.CookiesInterceptor$AddCookiesInterceptor.intercept(SourceFile:57)
at com.passbolt.mobile.android.core.networking.interceptor.CookiesInterceptor$ReceivedCookiesInterceptor.intercept(SourceFile:38)
at com.passbolt.mobile.android.core.networking.interceptor.AuthInterceptor.intercept(SourceFile:22)
at com.passbolt.mobile.android.core.networking.interceptor.ChangeableBaseUrlInterceptor.intercept(SourceFile:40)
at okhttp3.internal.connection.RealCall.getResponseWithInterceptorChain$okhttp(SourceFile:197)
at okhttp3.internal.connection.RealCall$AsyncCall.run(SourceFile:502)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1167)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:641)
at java.lang.Thread.run(Thread.java:923)
Caused by: java.security.cert.CertificateException: java.security.cert.CertPathValidatorException: Trust anchor for certification path not found.
at com.android.org.conscrypt.TrustManagerImpl.verifyChain(TrustManagerImpl.java:677)
at com.android.org.conscrypt.TrustManagerImpl.checkTrustedRecursive(TrustManagerImpl.java:554)
at com.android.org.conscrypt.TrustManagerImpl.checkTrusted(TrustManagerImpl.java:510)
at com.android.org.conscrypt.TrustManagerImpl.checkTrusted(TrustManagerImpl.java:428)
at com.android.org.conscrypt.TrustManagerImpl.getTrustedChainForServer(TrustManagerImpl.java:356)
at android.security.net.config.NetworkSecurityTrustManager.checkServerTrusted(NetworkSecurityTrustManager.java:94)
at android.security.net.config.RootTrustManager.checkServerTrusted(RootTrustManager.java:90)
at com.android.org.conscrypt.ConscryptEngineSocket$2.checkServerTrusted(ConscryptEngineSocket.java:161)
at com.android.org.conscrypt.Platform.checkServerTrusted(Platform.java:250)
at com.android.org.conscrypt.ConscryptEngine.verifyCertificateChain(ConscryptEngine.java:1644)
at com.android.org.conscrypt.NativeCrypto.ENGINE_SSL_read_direct(Native Method)
at com.android.org.conscrypt.NativeSsl.readDirectByteBuffer(NativeSsl.java:568)
at com.android.org.conscrypt.ConscryptEngine.readPlaintextDataDirect(ConscryptEngine.java:1095)
at com.android.org.conscrypt.ConscryptEngine.readPlaintextData(ConscryptEngine.java:1079)
… 35 more
Caused by: java.security.cert.CertPathValidatorException: Trust anchor for certification path not found.
… 49 more
… 35 more
… 49 more
00:35:11 There was an error during transfer update
… 35 more
… 49 more
… 35 more
… 49 more
If I understand correctly, this happens because of an incomplete certificate chain. I tried to make a certificate and a key (cert.pem and key.pem) following this instruction https://help.passbolt.com/faq/hosting/mobile-faq:
openssl req -x509 \
    -newkey rsa:4096 \
    -days 120 \
    -subj "/C=LU/ST=Luxembourg/L=Esch-Sur-Alzette/O=Passbolt SA/OU=Passbolt IT Team/CN=passbolt.domain.tld/" \
    -nodes \
    -addext "subjectAltName = DNS:passbolt.domain.tld" \
    -keyout key.pem \
    -out cert.pem
Next, I fixed the paths to new certificates in the passbolt container, in the nginx /etc/nginx/snippets/passbolt-ssl.conf configuration file:
##  Passbolt provided file to be included from nginx main virtual hosts file.
#  It allows to pull common SSL settings from a central place.
#  Use the nginx include directive to pull this information in.
  # Managed by Passbolt
  listen [::]:443 ssl http2;
listen 443 ssl http2;
  ssl_certificate /etc/ssl/certs/cert.pem;
  ssl_certificate_key /etc/ssl/certs/key.pem;
But even after that, when I scan the QR code, I get an error: “There was an error during transfer update” :frowning:
The browser on the computer only shows one certificate, not a chain of three certificates.
Help me please. How to properly configure the system?
Hello @hixr0k :wave: and welcome to passbolt community forum :people_holding_hands:
You are almost done :slight_smile: While using self-signed certificates, you have to import the generated certificate in your Android app.
You can follow instructions from this page: Passbolt Help | How to import SSL certificate on mobile application
Let me know if it fixes your issue.
There is not always 3 certificates in a full chain of trust for SSL, in case of your self-sign, there is only one.
One another hint, in our openssl command example, the certificate is valid for 4 months (-days 120 parameter.). You can increase it to avoid renewing certificate too often.
As I understand it, there is no way to import a .pem certificate into android.
I opened the local passbolt website (https://192.168.1.138) and clicked on the padlock icon and opened the certificate. I selected the “Details” tab and clicked the “Copy to File” button, then chose the “DER encoded binary X.509(.CER)” export format and saved the certificate. I was able to import the exported certificate into Android.
But it didn’t help me :frowning:
When scanning the QR, I see the error again: “There was an error during transfer update”.
When you generate your certificates with this command:
openssl req -x509 \
    -newkey rsa:4096 \
    -days 120 \
    -nodes \
    -keyout key.pem \
    -out cert.pem
You get 2 files:
  • key,pem
  • cert,pem
The generated cert.pem file is the certificate you want to be added in Android.
I noticed you are using an IP address instead of a domain name. As written in our documentation:
You can use an IP address instead of a domain name for your self-signed certificate. If you do that, replace DNS with IP in subjectAltName.
So in case of an IP address, the correct command is:
openssl req -x509 \
    -newkey rsa:4096 \
    -days 3650 \
    -subj "/C=LU/ST=Luxembourg/L=Esch-Sur-Alzette/O=Passbolt SA/OU=Passbolt IT Team/CN=192.168.1.138/" \
    -nodes \
    -addext "subjectAltName = IP:192.168.1.138" \
    -keyout key.pem \
    -out cert.pem
Yes, I originally did that, I forgot to write
If I’m right, then Android doesn’t import .pem certificates
I just generated SSL certificates with the command above, I copied the generated cert.pem on my Android phone (MI 9T PRO with Android 12.1) and I have been able to import the certificate.
Here is a video:
It doesn’t work for you ?
Thank you very much for the video! I finally found this menu section and installed the .pem certificate. When I get home, I will test the application on Android and write the result
Thank you for the video! After importing the certificate, it was possible to connect the application.
Great ! Thank you for your feedback and enjoy your self-hosted instance :wink:
