as usual I was updating my Passbolt-CE installation through apt on my Debian Trixie installed with extrepo.
Unfortunately this time there was also a PostgreSQL (my passbolt backend) update in the queue, and it didn’t come up in time for passbolt update.
so i got below error:
Setting up passbolt-ce-server (5.12.0-1) ...
Installing new version of config file /etc/passbolt/Migrations/20200501182000_V2130ReconcileLoginHistory.php ...
Installing new version of config file /etc/passbolt/app.default.php ...
Installing new version of config file /etc/passbolt/app.php ...
Installing new version of config file /etc/passbolt/bootstrap.php ...
Installing new version of config file /etc/passbolt/default.php ...
Installing new version of config file /etc/passbolt/requirements.php ...
Installing new version of config file /etc/passbolt/version.php ...
Running migration scripts.
using migration paths
- /etc/passbolt/Migrations
using seed paths
e[31m2026-05-15 03:34:02 error: [InvalidArgumentException] There was a problem connecting to the database: SQLSTATE[08006] [7] connection to server at "localhost" (::1), port 5432 failed: Connection refused
Is the server running on that host and accepting TCP/IP connections?
connection to server at "localhost" (127.0.0.1), port 5432 failed: Connection refused
Is the server running on that host and accepting TCP/IP connections? in /usr/share/php/passbolt/vendor/robmorgan/phinx/src/Phinx/Db/Adapter/PdoAdapter.php on line 114
Caused by: [PDOException] SQLSTATE[08006] [7] connection to server at "localhost" (::1), port 5432 failed: Connection refused
Is the server running on that host and accepting TCP/IP connections? in /usr/share/php/passbolt/vendor/robmorgan/phinx/src/Phinx/Db/Adapter/PdoAdapter.php on line 102e[0m
e[31m2026-05-15 03:34:02 error: Could not connect to Database.e[0m
<!DOCTYPE html>
<html class="passbolt no-js no-passboltplugin version" lang="en">
<head>
<meta charset="utf-8">
<title>Passbolt | Error</title>
<div id="container" class="error page error-500">
<div class="grid">
<div class="row">
<h2>An Internal Error Has Occurred</h2>
<p class="error">
An Internal Error Has Occurred. </p>
</div>
</div>
dpkg: error processing package passbolt-ce-server (--configure):
installed passbolt-ce-server package post-installation script subprocess returned error exit status 1
Errors were encountered while processing:
passbolt-ce-server
E: Sub-process /usr/bin/dpkg returned an error code (1)
and now
sudo -H -u www-data /usr/share/php/passbolt/bin/cake passbolt healthcheck
shows:
could someone help me in trying to solve the issue ? manually run a schema upgrade script ?
thanks a lot
