How to backup fingerprint?
I have Passbolt in a Docker container running in Synology NAS.
Health check told me that “This installation is not up to date. Currently using 2.8.1 and it should be v2.8.2.” (Later it turned out to be a wrong information, but it doesn’t matter now.)
Well, I exported all the settings of the container by Docker’s export function, and I also made a backup of the GPG keys. (Four files: serverkey_private.asc, serverkey.asc, unsecure_private.key, unsecure.key)
I did not delete the old container (just in case), but created a new one by the new image. (supposed to be v2.8.2)
Then I restored the GPG key files and all the settings (environment variables, etc.) to the new container.
Everything seems to be fine, but Healthchecker in the new instance says:
“The server key fingerprint doesn’t match the one defined in config/passbolt.php.”
I don’t have passpolt.php file (just passpolt.default.php), I set all the settings by environment variables.
If I login, in my profile I still can see the same fingerprint as before. The GPG keys have been recovered.
What exactly should I do to eliminate this error message? From where to where shall I copy fingerprint information?
(I’m quite noob, I’ll appreciate if you can be pretty specific and detailed in your answer.)
Thanks a lot in advance!
Hi @sawwee
That seems to be a false positive as the fingerprint is generated as an env variable on boot from your serverkey files.
We will look into it, thanks!
In the original instance I don’t receive this error message in healthcheck, only the new one is problematic, even though the two instances should be absolutely identical. What makes their to be different?
Do this two instances share the same domain name/ hostname? That could be the certificate mismatch
Same domain / hostname, even same ports. (I set the ports manually before running one or the other, because otherwise docker doesn’t let to set the same ports on both of the containers. At the end of the day the running one always have my original port setup.)
Could you try to source /etc/environment before launching the healthcheck?
Something like su -c "source /etc/environment; /var/www/passbolt/bin/cake passbolt healthcheck" -s /bin/bash www-data
Okay, I did that, launched healthcheck by the command you mentioned.
The two healthchecks are identical, except the fingerprint issue:
Original instance:
/ / __ `/ / / __ / __ / / _/
/ _
//.__/__//_/
[PASS] PHP version 7.2.16.
[PASS] Full base url is set to https://my.host.url
[PASS] 25 tables found
[FAIL] This installation is not up to date. Currently using 2.8.1 and it should be v2.8.3.
New instance:
/ _
//.__/__//_/
[FAIL] The server key fingerprint doesn’t match the one defined in config/passbolt.php.
[HELP] sudo su -s /bin/bash -c “gpg --list-keys --fingerprint --home /home/www-data/.gnupg” www-data | grep -i -B 2 ‘SERVER_KEY_EMAIL’
[PASS] The public key can be used to verify a signature
However…
I tried to follow the suggestion of the healthcheck result and double check the key fingerprint by the command mentioned in healthcheck result:
I tried it on both of the instances and finally the result was different! However still there were some similarities: there were two codes (I suppose these are the fingerprints) at both of the instances, and the second code of the first instance was the same as the first code of the second instance.
Like this:
Original instance:
pub   rsa2048 2019-04-02 [SC]
      40-digit code here  ("version A")
uid           [ultimate] My Name <my@email.address>
      another 40-digit code here ("version B")
uid           [ unknown] My Name <my@email.address>
New instance:
      same as "version B" 40 digit code here
      different 40 digit code here ("version C")
Well, how can I properly backup these codes from the original instance and restore it in the new instance? (I suppose this would solve my problem, wouldn’t it?)
Well, could you please help me with it?
Hey there have you been able to solve this issue?
Unfortunately not yet, I would still appreciate any respond to my last question. Thank you in advance!
Hey there,
Let’s dissect this a bit:
I assume on the code you pasted that the first output (the one that doesn’t complain about gpg fingerprint) is the result of executing:
This happens because on the docker-entrypoint.sh if the GPG_FINGERPRINT is not provided as an env variable the script tries to extract the data from the serverkeys present on the container and exports a variable so passbolt can continue operating normally. However, if you connect to the container using docker exec you won’t have that variable present because the current bash session you are using is not inheriting this particular env var. That’s why you have the fingerprint error and when sourcing /etc/environment you don’t have it, you could also workaround this issue getting the gpg fingerprint and running the container with that variable injected (PASSBOLT_GPG_SERVER_KEY_FINGERPRINT)
If you want to back up your serverkeys from your first instance you can just copy paste the /var/www/passbolt/config/gpg/serverkey*.asc from your first docker instance to your host machine and then mount them as host mounts into your new container (some examples on mounting files from host on the containers here or you could use docker volumes to persist /var/www/passbolt/config/gpg directory like what we propose here, exec on the container and overwrite the files.
Hope all this chunk of text helps you a bit :sweat_smile: and sorry for the late reply.
