razzak
#1
Setting up mariadb…
ERROR 1045 (28000): Access denied for user ‘root’@‘localhost’ (using password: NO)
Trying to connect to to mariadb with provided credentials…
Failed to enable unit: Unit file php7.2-fpm.service does not exist.
i am new to this and cannot find a solution to this problem during installation. Can some one please help?
Thank you very much.
Regards,
Razzak
Hi @razzak, In order to log into mariadb’s root user, your settings require you to be root on the server first. This is a mariadb security feature.
If you do not have php7.2-fpm, maybe you are on Ubuntu Desktop instead of server?
If you have another version of php7 running, maybe the following command will show you:
ps aux | grep php
This will list all processes that have “php” in their name.
razzak
#3
Hello Garrett,
thank you for your reply. i solved the ‘php7.2-fpm’ problem by going to the passbolt_ce_ubuntu_installer.sh file and changing 7.2 to 7.4.
Regards,
Razzak
system
closed
#4
