Invalid generation of pgp
use aws ami ,
The data entered are not correct: The OpenPGP public key should not be empty.; The OpenPGP private key should not be empty.; The fingerprint should not be empty.
gpg --armor --export-secret-keys **@email Generate PRIVATE KEY ,Paste into the browser, next returns the above error message
Hello @zxx,
Please, fill this template:
Can you explain a bit more precisely, is it the first time you are trying to log in into passbolt, was it working before? How can we reproduce this scenario?
Also, could you gives us the datacheck output
sudo su -s /bin/bash -c "/usr/share/php/passbolt/bin/cake passbolt datacheck --hide-success-details" www-data
For security purposes I have deleted your post, please do not share your private key.
Sometimes, there is an issue due to spaces after --- BEGIN PGP PRIVATE KEY BLOCK --- can you try to remove that empty space?
Removing spaces is also invalid
Does this issue is happening also if you are trying to create a gpg key from the webInstaller or is it only related to the key you are trying to import?
I refer to Passbolt Help | Using Passbolt CE AWS AMI
use gpg --armor --export-secret-keys email@domain.tld output content Paste to web page
Do you support importing in. txt format
gpg --armor --export-secret-keys MY-email@xxx > 123.txt
Error selecting file for import
Yes, .txt should work, I have reproduced the installation and the creation/import process (copy/paste + import .txt) of the gpg and I am not able to get the same error.
It could be related to a time synchronization issue, can you ensure that NTP is active and running as shown here
root@ip-172-16-0-159:~# timedatectl status
               Local time: Fri 2023-10-20 06:44:21 UTC
           Universal time: Fri 2023-10-20 06:44:21 UTC
                 RTC time: Fri 2023-10-20 06:44:21
                Time zone: Etc/UTC (UTC, +0000)
System clock synchronized: yes
              NTP service: active
          RTC in local TZ: no
Are there any other import methods?
AWS AMI deployment, forwarding intranet domain names through Ingress, passbolt not configured with 443, front-end checks are all HTTP requests, and configuring SSL certificates on the passbolt server to solve the problem
