La clave privada no corresponde con la clave pública restaurada
Hi everyone, sorry for my english.
I had this problem after restore my pasbolt instance.
¿Why does this error? The passbolt metadata key we used cannot be reused on another restored instance for the passwords and resources loaded from the MariaDB .SQL backup.
¿How do we solve it? In the configuration os the organization → Resource Types → Metadata key. At the bottom of this screen, we click “Rotate key.” Passbolt generated a new metadata key, and the resource metadata was re-encrypted using the new key. This eliminated the reference to the previous key that was causing the error.
Bye!
Hello, yes if you rotate the server key while in non-zero knowledge mode you will need to rotate it to reshare it with the new server key.
