Metadata encryption fails with 400 isPublicKeyValidStrict on fresh 5.10.0-2-ce-non-root and 5.9.0-1-ce-non-root Kubernetes installation
Environment:
  • Passbolt CE 5.10.0-2 non-root (Kubernetes, Helm chart)
  • Traefik v3 ingress controller with TLS termination
  • MariaDB 11.8.5, Redis 8.4.1
  • Tested on Chrome and Firefox (latest browser extension versions)
Steps to reproduce:
  1. Fresh install of Passbolt CE via Helm chart on Kubernetes
  2. Create first admin user via CLI (cake passbolt register_user)
  3. Complete account setup in browser with Passbolt extension
  4. Navigate to Organisation settings > Resource types > Getting started > Enable encrypted metadata and new resource types (recommended)
  5. Attempt to enable metadata encryption
  6. Error appears immediately
Issue:
Upon logging in and setting the passphrase for the admin user, an error regarding being unable to enable encryption for metadata is populated and a recommendation message to enable it in the Admin settings is also displayed. However, enabling metadata encryption from Organisation settings > Resource types > Getting started > Enable encrypted metadata and new resource types (recommended) > Save , failed and returned the error below:
    "code": 400,
    "body": {
        "armored_key": {
            "isPublicKeyValidStrict": "The armored key is not valid."
The error occurs when the browser extension submits the metadata PGP key to the API. It reproduces on both Chrome and Firefox with the latest extension versions.
Server-side checks all pass:
kubectl exec -it -n <passbolt-namespace> <passbolt-pod-name> -- \
  /usr/share/php/passbolt/bin/cake passbolt healthcheck --gpg
Defaulted container "passbolt" out of: passbolt, <passbolt-pod-name>-init (init)
 If you want to have more information about the different checks, please take a look at the documentation: https://www.passbolt.com/docs/admin/server-maintenance/passbolt-api-status/..
 [PASS] No error found. Nice one, sparky!
  /usr/share/php/passbolt/bin/cake passbolt healthcheck --metadata
 Metadata
GPG key details: RSA 3072/4096, Gopengpg compatible format.
Troubleshooting steps taken:
  • Verified GPG keyring permissions (all owned by www-data, UID 33)
  • Confirmed GPG fingerprint matches via healthcheck --gpg
  • Completely nuked the namespace, PVCs, secrets, and reinstalled from scratch — same error
  • Tested on both Passbolt CE 5.9.0-1 and 5.10.0-2 non-root — same error on both
  • Reproduced on both Chrome and Firefox with latest browser extensions
  • Verified network policies allow all required egress (SMTP, HTTPS, DNS confirmed working)
  • Tested with and without Traefik stripping X-Gpgauth-Debug and X-Gpgauth-Error response headers
  • Confirmed metadata_keys database table is empty (no corrupt entry from a prior failed attempt)
Note: Metadata encryption was successfully enabled on a separate 5.9.0 CE non-root Kubernetes instance set up about a month ago with an older passbolt browser extension version (5.10.4). Could this issue be tied to the recent browser extension update (5.11.0)?
I’d appreciate any assistance or guidance. Thank you.
Edit:
The latest passbolt browser extension (5.11.1) rectified the issue. Encrypted Metadata works now on passbolt v.5.10.0-2-ce-non-root (Kubernetes installation).
