Not loading the group items
[ x] I have read intro post: https://community.passbolt.com/t/about-the-installation-issues-category/12
Hi team,
I recently upgraded Passbolt to the latest Docker version.
As part of the process, I restored the database into a new Docker volume to keep the data.
After the migration, I noticed a strange behavior:
Whenever I go to “Users” → “Manage users & groups”, the page starts loading but never finishes.
During this time, the entire Passbolt web interface becomes unresponsive — I can’t navigate anywhere else, and it feels like the system hangs.
After a few minutes, the interface recovers and becomes usable again.
This problem did not happen in the old environment (the previous container and database worked normally).
Details of my setup:
  • Passbolt Community Edition (latest Docker image)
  • MariaDB database
  • Environment variables configured in .env file
  • Using Gmail SMTP for email delivery
What I already tried:
  • Restarting the container
  • Clearing browser cache / trying different browsers
  • Checking container logs (didn’t see obvious errors)
Symptoms:
  • Click on “Manage users & groups”
  • Loading spinner keeps spinning
  • System becomes slow / almost hangs
  • After some time, it recovers and becomes usable again
Has anyone else faced this after upgrading and restoring the database?
Any suggestions on what might cause this or how to debug?
Thanks a lot! :folded_hands:
Here a copy of my healthcheck:
 [INFO] Linux 8da35bf40f3f 5.15.0-134-generic #145-Ubuntu SMP Wed Feb 12 20:08:39 UTC 2025 x86_64 GNU/Linux
 [PASS] PHP version 8.2.28.
 [HELP] See `timedatectl | grep -i -A 1 clock`. More information: https://www.passbolt.com/docs/hosting/configure/ntp/
 [PASS] Full base url is set to https://192.168.1.239:8888
 SMTP settings
 [FAIL] A valid JWT key pair is missing.
 [HELP] Run the create JWT keys script to create a valid JWT secret and public key pair:
 [HELP] sudo su -s /bin/bash -c "/usr/share/php/passbolt/bin/cake passbolt create_jwt_keys" www-data
 [HELP] you can try:
 [PASS] Using latest passbolt version (5.2.0).
 [PASS] 34 tables found.
 Metadata
 [FAIL] 9 error(s) found. Hang in there!
The error looks like this:
Can someone help me with this? The db table group_users has all the records here but the front keeps breaking and doesn’t shows any errors in console
Can you share your HAR
to support@passbolt.com for us to have a look
Thanks!
