I have been having some issues with the autofill-feature with the Firefox extension.
About half of the time the extension keeps spinning after I click on “use on this page”. When that message appears I have to manually find the password through all the groups and folders, then copy the email, find the password through all the groups and folders again and then copy the password.
The issue appears over multiple websites at random. Sometimes the autofill feature works for one website and then suddenly stops working. This issue exists on multiple computers and websites.
How can this be fixed? I really don’t want to manually do this every single time I want to autofill a password.
Please look through some of these and see if it matches what you are experiencing. If you need help checking anything in your particular situation, just post back.
This happens for around 20-30% of all password autofills that I do. Sometimes it works by simply refreshing the page 5-6 times or even closing the tab and opening it up again.
My specs
Intel Core i9
Firefox
Windows 10 64 bit
32 GB RAM
RX6700
1GBPS Network, no VPN
