I use Passbolt since few month and it works perfectly.
Except when I want to autocomplete a pop-up box with my credentials.
I select the right credential and click on “use on this page” button but nothing…
Do you have a solution?
This could be a case where the site’s HTML code for the pop-up modal does not include the needed attribute for autocomplete. Here’s what to look for: HTML input autocomplete Attribute
Hi @garrett and thank you!
I can’t access this part of code so I can’t see if it include the attributes for autocomplete…
So, I have to continue to manually copy/paste the credentials.
Thank you very much
