Passbolt CE 5.17.0 upgrade blocked by SELinux dependency on openSUSE Leap 15.6
I’m running Passbolt Community Edition 5.15.0 on openSUSE Leap 15.6 and am trying to upgrade to version 5.17.0.
Unfortunately, the upgrade is blocked by a dependency on passbolt-server-selinux, which in turn requires a Fedora-specific SELinux policy package that is not available on openSUSE Leap 15.6.
Since openSUSE Leap uses AppArmor rather than SELinux by default, I suspect this may be an issue with the RPM packaging or dependency definitions for version 5.17.0.
1. System information
Component Version / Configuration
Operating system openSUSE Leap 15.6
Kernel 6.4.0-150600.23.103-default
Passbolt edition Community Edition (CE)
Currently installed version 5.15.0-1
Available version 5.17.0-1
PHP 8.2.30
Web server nginx 1.21.5
PHP-FPM PHP 8.2
Active security module AppArmor
Installation method Official Passbolt CE RPM repository
The official repository is configured as follows:
[passbolt-server]
name=Passbolt Server
baseurl=https://download.passbolt.com/ce/rpm/opensuse/stable
enabled=1
gpgcheck=1
gpgkey=https://download.passbolt.com/pub.key
2. Problem description
When attempting to upgrade Passbolt using:
zypper update --dry-run passbolt-ce-server
Zypper reports the following dependency conflict:
Problem: 1: nothing provides 'selinux-policy-base >= 3.13.1-128.6.fc22' needed by the to be installed passbolt-server-selinux-0.7-1.noarch
Solution 1: do not install passbolt-ce-server-5.17.0-1.noarch
Solution 2: break passbolt-server-selinux-0.7-1.noarch by ignoring some of its dependencies
I cancelled the operation rather than forcing an installation with unresolved dependencies.
Interestingly, zypper list-updates reports no updates, while zypper list-updates --all correctly identifies Passbolt 5.17.0 as available.
3. Dependency comparison
The currently installed Passbolt CE 5.15.0 package does not require passbolt-server-selinux.
However, the available Passbolt CE 5.17.0 package explicitly includes it as a required dependency.
Output from:
zypper info --requires passbolt-ce-server
Relevant section:
Version    : 5.17.0-1
Repository : Passbolt Server
Requires:
    /usr/bin/env
    nginx
    /bin/bash
    cronie
    php-gnupg
    php-pecl
    php >= 8.2
    php-cli >= 8.2
    php-curl >= 8.2
    php-fileinfo >= 8.2
    php-fpm >= 8.2
    php-gd >= 8.2
    php-intl >= 8.2
    php-json >= 8.2
    php-mbstring >= 8.2
    php-mysql >= 8.2
    php-openssl >= 8.2
    php-pgsql >= 8.2
    php-posix >= 8.2
    php-xmlreader >= 8.2
    php-xmlwriter >= 8.2
    php-ldap >= 8.2
The SELinux package is available in the official Passbolt repository:
Version    : 0.7-1
However, it cannot be installed because of its dependency on:
The fc22 version suffix suggests a Fedora-specific dependency.
4. SELinux / AppArmor verification
The active Linux Security Modules were verified using:
cat /sys/kernel/security/lsm
Output:
lockdown,capability,apparmor,bpf
The SELinux policy package is not installed:
rpm -q selinux-policy-base
Output:
package selinux-policy-base is not installed
Likewise, passbolt-server-selinux is not currently installed:
rpm -q passbolt-server-selinux
Output:
package passbolt-server-selinux is not installed
5. Troubleshooting performed
I have completed the following checks:
  1. Verified that the repository URL matches the official Passbolt CE repository for openSUSE.
  2. Refreshed all repositories using zypper refresh.
  3. Confirmed that Passbolt 5.17.0 is available using zypper list-updates --all.
  4. Reproduced the dependency conflict using zypper update --dry-run passbolt-ce-server.
  5. Compared the installed 5.15.0 package dependencies with the available 5.17.0 package.
  6. Confirmed that the new package requires passbolt-server-selinux.
  7. Verified that AppArmor is active and SELinux is not listed among the active Linux Security Modules.
  8. Confirmed that neither selinux-policy-base nor passbolt-server-selinux is installed.
No dependency overrides or forced installations have been attempted.
6. Steps to reproduce
On an openSUSE Leap 15.6 system with Passbolt CE 5.15.0 installed:
  1. Configure the official Passbolt CE openSUSE stable repository.
  2. Execute zypper refresh.
  3. Execute zypper list-updates --all to verify that 5.17.0 is available.
  4. Execute zypper update --dry-run passbolt-ce-server.
  5. Observe the dependency conflict involving passbolt-server-selinux and selinux-policy-base.
7. Current Passbolt healthcheck
The existing Passbolt CE 5.15.0 installation is operational.
The healthcheck confirms:
[PASS] PHP version 8.2.30.
[PASS] The application is able to connect to the database.
[PASS] The database version is supported.
[PASS] The model schema cache shows no discrepancies with the database schema.
[FAIL] This installation is not up to date.
       Currently using 5.15.0 and it should be 5.17.0.
[FAIL] 1 error(s) found.
The only remaining healthcheck failure is the outdated Passbolt version. There are also non-fatal configuration warnings.
8. Questions
Could someone from the Passbolt team please clarify the following?
  1. Is passbolt-server-selinux intentionally a mandatory dependency for the openSUSE Leap RPM package, even on systems using AppArmor?
  2. Could this be an RPM packaging issue introduced between Passbolt CE 5.15.0 and 5.17.0?
  3. Is there an officially supported method to upgrade to 5.17.0 without installing passbolt-server-selinux or bypassing RPM dependency checks?
  4. If this is a packaging issue, is a corrected RPM package planned?
Since this is a production password manager, I would prefer to avoid forcing the installation or leaving unresolved RPM dependencies.
Any guidance would be appreciated.
Thanks in advance!
Hi BlackAdderDK,
Thanks for the detailed report and for taking the time to investigate before forcing anything on a production server.
You’re right: the upgrade to 5.17.0 is blocked because the openSUSE package now requires passbolt-server-selinux, which in turn depends on an SELinux policy package that isn’t available on openSUSE Leap 15.6.
The upcoming unification of the CE and Pro packages could solve this issue. We tried to release it recently but had to go back because of some issues. We are working on it and will try again before the end of the year otherwise we might drop support for RHEL9/openSUSE 15.X. We will keep this thread updated.
If you’d rather not wait, you can migrate your installation to openSUSE 16 and follow our migration guide. Before migrating, make sure you take a full backup (database, /etc/passbolt, server GPG keys and JWT keys), following this documentation.
Sorry for the inconvenience, and thanks again for the clear report.
Happy to help.
Thomas.
Hi :waving_hand:,
Regarding your third point:
I would like to add that we don’t have any officially supported method to do that.
As a temporary solution, it’s fine to bypass the passbolt-server-selinux dependency, as it can be ignored if you’re not enforcing/using SELinux policies, until you’re able to migrate to openSUSE 16. This can be done at upgrade time when using the usual zypper update command.
Our choice to drop 15.6 support was also motivated by the fact that it had been end of life since April of 2026 and that 16 now has SELinux configured and enabled by default.
Best regards,
Louis
On Leap 15.6 the SELinux policy package often lags the Passbolt RPM. I usually install the matching passbolt-ce-server-selinux (or temporarily set the httpd context on /etc/passbolt and the web root), run restorecon -Rv, then nginx -t / reload before retrying the upgrade. If the dependency is hard-blocked, pin the previous CE package until the SELinux module ships—don’t disable SELinux globally just to get past the transaction.
