Passbolt does not email users
Hi everyone, I have a problem, I’m using the free version of passbolt, after restarting the server I find that when a user registers in passbolt they don’t receive the email to register after the invitation. Can you tell me what to check and what to do?
Thank you,
I await feedback
Greetings
Hi @marco.sabatino ,
Are other emails correctly sent?
Did you try sending a test email in the email server section under the administration section?
Hi, no e-mail arrives, no one at all. As for the email test, it doesn’t give me the option as there is an email alias inserted. But before that it worked fine
Which version of passbolt are you using?
Could you paste your healthcheck here?
The version is as follows: 3.8.0. What do you mean by health check?
Do you need passbolt system logs? Can you tell me the route please? Thank you!
If I go inside the path var/log/passbolt, I find this error with the txt file with today’s date:
2023-11-07 07:43:46 error: [Authentication\Authenticator\UnauthenticatedException] Authentication is required to continue in /usr/share/php/passbolt/vendor/cakephp/authentication/src/Controller/Component/AuthenticationComponent.php on line 177
Client IP: 192.168.2.31
2023-11-07 08:00:55 error: [Authentication\Authenticator\UnauthenticatedException] Authentication is required to continue in /usr/share/php/passbolt/vendor/cakephp/authentication/src/Controller/Component/AuthenticationComponent.php on line 177
Client IP: 192.168.2.46
2023-11-07 08:03:00 error: [Authentication\Authenticator\UnauthenticatedException] Authentication is required to continue in /usr/share/php/passbolt/vendor/cakephp/authentication/src/Controller/Component/AuthenticationComponent.php on line 177
Client IP: 192.168.2.44
2023-11-07 08:05:04 error: [Authentication\Authenticator\UnauthenticatedException] Authentication is required to continue in /usr/share/php/passbolt/vendor/cakephp/authentication/src/Controller/Component/AuthenticationComponent.php on line 177
Client IP: 192.168.2.41
2023-11-07 08:19:48 error: [Authentication\Authenticator\UnauthenticatedException] Authentication is required to continue in /usr/share/php/passbolt/vendor/cakephp/authentication/src/Controller/Component/AuthenticationComponent.php on line 177
Client IP: 192.168.2.68
2023-11-07 08:20:39 error: [Authentication\Authenticator\UnauthenticatedException] Authentication is required to continue in /usr/share/php/passbolt/vendor/cakephp/authentication/src/Controller/Component/AuthenticationComponent.php on line 177
Client IP: 192.168.2.26
2023-11-07 08:21:32 error: [Authentication\Authenticator\UnauthenticatedException] Authentication is required to continue in /usr/share/php/passbolt/vendor/cakephp/authentication/src/Controller/Component/AuthenticationComponent.php on line 177
Request URL: /users/me.json?api-version=v2
Client IP: 192.168.2.43
2023-11-07 08:36:32 error: [Authentication\Authenticator\UnauthenticatedException] Authentication is required to continue in /usr/share/php/passbolt/vendor/cakephp/authentication/src/Controller/Component/AuthenticationComponent.php on line 177
2023-11-07 08:44:52 error: [Authentication\Authenticator\UnauthenticatedException] Authentication is required to continue in /usr/share/php/passbolt/vendor/cakephp/authentication/src/Controller/Component/AuthenticationComponent.php on line 177
Client IP: 192.168.2.48
2023-11-07 08:45:57 error: [Authentication\Authenticator\UnauthenticatedException] Authentication is required to continue in /usr/share/php/passbolt/vendor/cakephp/authentication/src/Controller/Component/AuthenticationComponent.php on line 177
Client IP: 192.168.2.47
2023-11-07 08:51:32 error: [Authentication\Authenticator\UnauthenticatedException] Authentication is required to continue in /usr/share/php/passbolt/vendor/cakephp/authentication/src/Controller/Component/AuthenticationComponent.php on line 177
2023-11-07 09:01:19 error: [Authentication\Authenticator\UnauthenticatedException] Authentication is required to continue in /usr/share/php/passbolt/vendor/cakephp/authentication/src/Controller/Component/AuthenticationComponent.php on line 177
2023-11-07 09:01:23 error: [Authentication\Authenticator\UnauthenticatedException] Authentication is required to continue in /usr/share/php/passbolt/vendor/cakephp/authentication/src/Controller/Component/AuthenticationComponent.php on line 177
2023-11-07 09:21:03 error: [Authentication\Authenticator\UnauthenticatedException] Authentication is required to continue in /usr/share/php/passbolt/vendor/cakephp/authentication/src/Controller/Component/AuthenticationComponent.php on line 177
2023-11-07 09:21:08 error: [Authentication\Authenticator\UnauthenticatedException] Authentication is required to continue in /usr/share/php/passbolt/vendor/cakephp/authentication/src/Controller/Component/AuthenticationComponent.php on line 177
2023-11-07 10:47:09 error: [Authentication\Authenticator\UnauthenticatedException] Authentication is required to continue in /usr/share/php/passbolt/vendor/cakephp/authentication/src/Controller/Component/AuthenticationComponent.php on line 177
2023-11-07 10:47:13 error: [Authentication\Authenticator\UnauthenticatedException] Authentication is required to continue in /usr/share/php/passbolt/vendor/cakephp/authentication/src/Controller/Component/AuthenticationComponent.php on line 177
2023-11-07 10:47:26 error: [Authentication\Authenticator\UnauthenticatedException] Authentication is required to continue in /usr/share/php/passbolt/vendor/cakephp/authentication/src/Controller/Component/AuthenticationComponent.php on line 177
2023-11-07 12:45:37 error: [Authentication\Authenticator\UnauthenticatedException] Authentication is required to continue in /usr/share/php/passbolt/vendor/cakephp/authentication/src/Controller/Component/AuthenticationComponent.php on line 177
Client IP: 192.168.2.52
2023-11-07 12:49:06 error: [Authentication\Authenticator\UnauthenticatedException] Authentication is required to continue in /usr/share/php/passbolt/vendor/cakephp/authentication/src/Controller/Component/AuthenticationComponent.php on line 177
2023-11-07 13:10:02 error: [Authentication\Authenticator\UnauthenticatedException] Authentication is required to continue in /usr/share/php/passbolt/vendor/cakephp/authentication/src/Controller/Component/AuthenticationComponent.php on line 177
2023-11-07 13:32:22 error: [Authentication\Authenticator\UnauthenticatedException] Authentication is required to continue in /usr/share/php/passbolt/vendor/cakephp/authentication/src/Controller/Component/AuthenticationComponent.php on line 177
2023-11-07 13:43:08 error: [Authentication\Authenticator\UnauthenticatedException] Authentication is required to continue in /usr/share/php/passbolt/vendor/cakephp/authentication/src/Controller/Component/AuthenticationComponent.php on line 177
2023-11-07 13:46:20 error: [Authentication\Authenticator\UnauthenticatedException] Authentication is required to continue in /usr/share/php/passbolt/vendor/cakephp/authentication/src/Controller/Component/AuthenticationComponent.php on line 177
2023-11-07 13:59:40 error: [Authentication\Authenticator\UnauthenticatedException] Authentication is required to continue in /usr/share/php/passbolt/vendor/cakephp/authentication/src/Controller/Component/AuthenticationComponent.php on line 177
2023-11-07 14:21:50 error: [Authentication\Authenticator\UnauthenticatedException] Authentication is required to continue in /usr/share/php/passbolt/vendor/cakephp/authentication/src/Controller/Component/AuthenticationComponent.php on line 177
The healthcheck command specific to SMTP settings would be:
su -s /bin/bash -c "/usr/share/php/passbolt/bin/cake passbolt healthcheck --smtpSettings" www-data
Also you can test your email settings by sending an email via the command line:
su -s /bin/bash -c "/usr/share/php/passbolt/bin/cake passbolt send_test_email -r your-email@your-domain.com" www-data
Hi, after the verification command the problem was resolved. Thank you very much. Greetings
