I am trying to update my passbolt from v2.8.3 to v3.12.0-3 (Docker).
Here my docker-compose file :
version: '3.4'
db:
image: mariadb:10.3
container_name : mariadb_passbolt
restart: always
env_file:
- env/mysql.env
- "127.0.0.1:3306:3306"
image: passbolt/passbolt:3.12.0-3
container_name: passbolt
restart: always
tty: true
depends_on:
- db
env_file:
- env/passbolt.env
- gpg_volume:/var/www/passbolt/config/gpg
- images_volume:/var/www/passbolt/webroot/img/public
- ./certs/cert.pem:/etc/ssl/certs/certificate.crt:ro
- ./certs/key.pem:/etc/ssl/certs/certificate.key:ro
tmpfs:
- /run
command: ["/usr/bin/wait-for.sh", "db:3306", "--", "/docker-entrypoint.sh"]
- 80:80
- 443:443
database_volume:
gpg_volume:
images_volume:
I first had a nginx 502 error which I solved in creating a “php” folder in /run folder in my passbolt container.
Now I am in the first configuration page of passbolt where I need to enter my database url.
I have tried 127.0.0.1 (port 3306) and IP adress of my server but it says “connection could not be established…”
I have check that my mariadb docker is running and I am able to connect to it using “docker exec -it mariadb_passbolt bash” and “mysql -u passbolt - p” then entering my password.
I do not know what do to next…
Let me know if you have any suggestion?
Thanks,
Michael
