I have been running passbolt ce fine for at a couple of month but something went wrong after doing a docker pull and the “sudo docker-compose up --force-recreate --build passbolt”
Im running on Synology NAS with composer:
passboltdb:
container_name: passboltdb
image: mariadb:10.3
#image : mariadb:10.3.20
restart: always
MYSQL_RANDOM_ROOT_PASSWORD: “true”
MYSQL_DATABASE: “passbolt”
MYSQL_USER: “XXXXXXXXXXXXXXXXXXXXXX”
MYSQL_PASSWORD: “XXXXXXXXXXXXXXXXXXXXXX”
- /volume2/docker/passbolt/db:/var/lib/mysql rw
networks:
- passbolt
restart: unless-stopped
depends_on:
- passboltdb
APP_FULL_BASE_URL: https://passbolt.davra.dk
DATASOURCES_DEFAULT_HOST: “passboltdb”
DATASOURCES_DEFAULT_USERNAME: “XXXXXXXXXXXXXXXXXXXXXX”
DATASOURCES_DEFAULT_PASSWORD: “XXXXXXXXXXXXXXXXXXXXXX”
DATASOURCES_DEFAULT_DATABASE: “passbolt”
EMAIL_TRANSPORT_DEFAULT_HOST: "smtp.gmail.com"
EMAIL_TRANSPORT_DEFAULT_PORT: "587"
EMAIL_TRANSPORT_DEFAULT_USERNAME: "XXXXXXXXXXXXXXXXXXXXXX"
EMAIL_TRANSPORT_DEFAULT_PASSWORD: "XXXXXXXXXXXXXXXXXXXXXX"
- /volume2/docker/passbolt/gpg:/etc/passbolt/gpg rw
- /volume2/docker/passbolt/jwt_volume:/etc/passbolt/jwt rw
- /volume2/docker/passbolt/images:/usr/share/php/passbolt/webroot/img/public rw
command: ["/usr/bin/wait-for.sh", "-t", "0", "passboltdb:3306", "--", "/docker-entrypoint.sh"]
- 8088:80
networks:
- passbolt
healthcheck
// _,///./_//__/
[PASS] PHP version 7.4.30.
[PASS] Full base url is set to
[PASS] 26 tables found
[FAIL] The server key fingerprint doesn’t match the one defined in config/passbolt.php.
[HELP] sudo su -s /bin/bash -c “gpg --list-keys --fingerprint --home /var/lib/passbolt/.gnupg” root | grep -i -B 2 ‘SERVER_KEY_EMAIL’
[HELP] you can try:
[HELP] sudo su -s /bin/bash -c “gpg --home /var/lib/passbolt/.gnupg --import /etc/passbolt/gpg/serverkey_private.asc” root
[FAIL] This installation is not up to date. Currently using 3.7.3 and it should be v3.8.0.
[FAIL] 5 error(s) found. Hang in there!
How do I fix the problem?
Best regards Jakob
