I can send test emails successfully (they don’t go to spam), but I can’t get it to work with my Passbolt installation. It’s always the error ‘connection refused’, for tcp://localhost:587. Any particular settings you can recommend? Thanks in advance.
We need more informations about what is happening.
Could you please fill the checklist?
With thoses informations, it will be easier for me to reproduce your issue.
This is the error I get:
“stream_socket_client(): Unable to connect to tcp://localhost:587 (Connection refused)”
I suspect there is something wrong with my SMTP server settings for Passbolt, since I can send email via mail (bash) and ports 587 and 465 are allowed in the firewall.
Thanks in advance!
Hi @Bert if you are installing postfix locally, the firewall ports for incoming traffic do not need to be open, especially if you are attempting SMTP without authentication. The inet_interfaces setting to loopback should prevent postfix from listening on all ports, but no need to open ports that won’t be needed.
Postfix will listen on local ports and you might want to try 127.0.0.1 for the host. Also, TLS would not be needed because you are connecting locally, compared to coming in from an external source.
Making these changes may not completely resolve the issue, but might get you different errors to pursue.
