Is it possible that the SUSE Package repository for Passbolt CE has not had any updates since v4.7.0, hence currently missing versions 4.7.7, 4.7.8 and 4.8.0 ?
2024/06/14 17:12:50 +02:00 Command: ['/usr/bin/spacewalk-repo-sync', '--channel', 'passbolt-server-ce-suse15-x86_64', '--type', 'yum', '--non-interactive']
2024/06/14 17:12:50 +02:00 Sync of channel started.
2024/06/14 17:12:51 +02:00 Repo URL: https://download.passbolt.com/ce/rpm/opensuse/stable
2024/06/14 17:12:51 +02:00 Packages in repo: 25
2024/06/14 17:12:52 +02:00 No new packages to sync.
2024/06/14 17:12:52 +02:00 Patches in repo: 0.
2024/06/14 17:12:52 +02:00 Sync completed.
As you can see, there was one new package added, but it is the PRO version on the CE repository. Also only 4.8.0 was added, I don’t think I would need 4.7.7 or 4.7.8 specifically myself, but it is best that they should still be added too, I assume ?
