After 3 days i finally install passbolt over docker, without any issue, but i dont know why its become very slow.
i am using sef-generate ssl, and using local IP address
my first attempo to access SSL works, after a while, firefox show warning about ssl and now i lost the locker (ssl) and stayed with an insecure connection, i dont know if is correlated, because i have another installation using non secure connection and its very fast.
btw, any tip from where i start?
hardware is super fast,
8vcores + 2gb ram + 40gb space (nvme 4.0)
Host = almalinux 9 + Docker
any light?
healthcheck
[INFO] Linux 3fa80df375af 5.14.0-503.11.1.el9_5.x86_64 #1 SMP PREEMPT_DYNAMIC Tue Nov 12 09:26:13 EST 2024 x86_64 GNU/Linux
[PASS] PHP version 8.4.11.
[INFO] gpg (GnuPG) 2.4.7 / libgcrypt 1.11.0
[HELP] See timedatectl | grep -i -A 1 clock. More information: https://www.passbolt.com/docs/hosting/configure/ntp/
[PASS] Full base url is set to https://192.168.0.13
SMTP settings
[PASS] The SMTP Settings plugin endpoints are disabled.
[PASS] Using latest passbolt version (5.6.0).
[PASS] 34 tables found.
Metadata
[PASS] No error found. Nice one, sparky!
