(changing slashes to underscore because 2-link-posting-policy)
We are supplying config using the following env-vars
APP_FULL_BASE_URL = ##########
DATASOURCES_DEFAULT_DATABASE = passbolt (name of mysql-database with utf8_general_ci collation)
DATASOURCES_DEFAULT_HOST = #######.mysql.database.azure.com
DATASOURCES_DEFAULT_USERNAME = passbolt
DATASOURCES_DEFAULT_PASSWORD = #############
DATASOURCES_DEFAULT_SSL_CA = _full_path_to_BaltimoreCyberTrustRoot.ca.pem
Done troubleshooting
We have confirmed that mounting the CA-cert works
We have other working services in same K8-cluster using the same MySQL-service
To reproduce
(using instructions from the “Docker passbolt installation”-page)
File “BaltimoreCyberTrustRoot.ca.pem” is located in $(pwd)
docker run -a STDOUT -a STDERR --rm --name passbolt -p 443:443 -p 80:80 -v "$(pwd)":/dockermount -e DATASOURCES_DEFAULT_HOST=#######.mysql.database.azure.com -e DATASOURCES_DEFAULT_PASSWORD=############# -e DATASOURCES_DEFAULT_USERNAME=passbolt -e DATASOURCES_DEFAULT_DATABASE=passbolt -e DATASOURCES_DEFAULT_SSL_CA=_dockermount_BaltimoreCyberTrustRoot.ca.pem -e APP_FULL_BASE_URL==############# passbolt_passbolt:latest
Log
gpg; directory ‘home_www-data.gnupg’ created
gpg; keybox ‘home_www-data.gnupg_pubring.kbx’ created
gpg; home_www-data.gnupg_trustdb.gpg; trustdb created
gpg; key 7B9453509FD22A59 marked as ultimately trusted
gpg; directory ‘home_www-data.gnupg_openpgp-revocs.d’ created
gpg; revocation certificate stored as ‘home_www-data.gnupg_openpgp-revocs.d_524D3E2CD1A7342BCFD16DF97B9453509FD22A59.rev’
gpg; key 7B9453509FD22A59; “Passbolt default user <passbolt(at)yourdomain_com>” not changed
gpg; Total number processed; 1
gpg; unchanged; 1
gpg; key 7B9453509FD22A59; secret key imported
gpg; unchanged; 1
gpg; secret keys read; 1
gpg; secret keys unchanged; 1
Generating a RSA private key
writing new private key to ‘_etc_ssl_certs_certificate.key’
gpg; checking the trustdb
gpg; marginals needed; 3 completes needed; 1 trust model; pgp
gpg; depth; 0 valid; 1 signed; 0 trust; 0-, 0q, 0n, 0m, 0f, 1u
(passbolt-banner)
Running baseline checks, please wait… Exception; SQLSTATE[HY000] [2002] in [_var_www_passbolt_vendor_cakephp_cakephp_src_Database_Driver.php, line 92]
(passbolt-banner)
Running migration scripts.
using migration paths
_var_www_passbolt_config_Migrations
using seed paths
_var_www_passbolt_config_Seeds Exception; There was a problem connecting to the database; SQLSTATE[HY000] [2002] in [_var_www_passbolt_vendor_robmorgan_phinx_src_Phinx_Db_Adapter_MysqlAdapter.php, line 127]
Hi @HansB, I might check with the MySQL end of things and see if there are error logs. Not knowing the incoming host could be an issue, or security requirements maybe? If there is nothing there you might want to make sure passbolt can resolve the Azure mysql url you provided.
Well, I do think the DNS-resolution works just fine, because if I omit the SLL_CA-env-var in the docker-command the 2 “Exception”-lines becomes:
Exception: SQLSTATE[HY000] [9002] SSL connection is required. Please specify SSL options and retry. in [/var/www/passbolt/vendor/cakephp/cakephp/src/Database/Driver.php, l
ine 92]
and
Exception: There was a problem connecting to the database: SQLSTATE[HY000] [9002] SSL connection is required. Please specify SSL options and retry. in [/var/www/passbolt/v
endor/robmorgan/phinx/src/Phinx/Db/Adapter/MysqlAdapter.php, line 127]
The following works just fine from my workstation: <?php ini_set ('error_reporting', E_ALL); ini_set ('display_errors', '1'); error_reporting (E_ALL|E_STRICT);
When i try to run it in the passbolt-image PHP says: “Call to undefined function mysqli_init()”
I’ve tried to add php_mysql (with variants) using apt install but that can’t be found. (missing some source maybe) (did some searching on the errors but nothing seemed to allow me to install that package)
I have succesfully ran passbolt against azure mysql instance using SSL with the following parameters (using docker-compose stack provided in https://github.com/passbolt/passbolt_docker)
Ensure the pem file is mounted with proper permissions so www-data user can read it. Also ensure an empty database schema exists on the azure instance and that the user you are using has the proper rights to access and create tables on it.
After some more tries I’ve managed to get passbolt to start and talk to the database when I run a local docker-image, so the SSL-part works and this issue can be closed.
I’ve yet to get it to in our Kubernetes-cluster (in same cluster as a Grafana-instance that already talks to that same MySQL-server, so there is no firewalling-issue that’s the issue.
