Raspberry Pi OS Lite Unable to locate package
Hello all!
I am attempting to install Passbolt CE on a Pi 3 B rev 1.2 following the steps in the tutorial Passbolt Help | Install Passbolt CE on Raspberry PI however I am being met with errors “E: Unable to locate package passbolt-ce-server” per screenshot:
I did attempt to see in the Installation Issues category if there were similar issues, however the two most similar topics did not seem to yield results. Problem with the repo?
Thank you in advance for any support.
Hi @itsmaurits :wave: and welcome to passbolt community forum.
I think there is a typo in our configuration script.
Can you open /etc/apt/sources.list.d/passbolt.sources and replace https://download.passbolt.com/pro/raspbian with https://download.passbolt.com/pro/debian
Your passbolt.sources file should be like the one below:
Types: deb
URIs: https://download.passbolt.com/pro/debian
Suites: buster
Components: stable
Signed-By: /usr/share/keyrings/passbolt-repository.gpg
Thank you, @AnatomicJC
EDIT:
I have now managed to install Passbolt CE.
Thanks for reporting this to us :+1: , we will fix our installation script to handle raspberry pi.
still has not been fixed trid this method does not work
unless im doing it wrong how do you edit the sources file
hey @z24god I see you have posted in two different topics about something not working, could you create a new topic in Installation Issues that answers the questions in the checklist? Then we’ll be able to assist you
