Remote mysql db connection with docker-compose
I am using docker-compose, but instead of the local docker mysql db I want to use an existing db cluster which is setup for backup.
To this end I modified the docker-compose file; copied below
  • remove the db service and its dependency under passbolt
  • updated the environment variables as below
The following behaviour happens
  1. docker-compose ps gives me status = running for passbolt.
  2. docker compose logs gives me only 1 line; waiting for timeout. I set the DEBUG variable to true and still only 1 line.
  3. no tables get created in the db so passbolt is probably not connecting
  4. the exec command to setup first user gives me output “Exception: SQLSTATE[42S02]: Base table or view not found: 1146 Table ‘passbolt.users’ doesn’t exist”
  5. i checked that if i connect to mysql from the same host where I have passbolt, copy/pasting the values from docker-compose-ce.yaml. I then check that user can see that database and create a test table.
  6. curl to the mapped ports (localhost:8090, localhost:8091) fails
Notes:
  • this is running on amazon linux x86_64, using docker-compose
  • i have not set the env variables for the SMTP; but i expect to be able to start the service without the email configuration and do the email part later so i dont think this is the first problem to solve
  • I tried the DATASOURCES_DEFAULT_HOST with and without the mysql prefix; both “mysql://url.amazonrds.com” and “url.amazonrds.com”
  • the value for APP_FULL_BASE_URL points to a load balancer, so if passbolt tries to request to that value it will get an error until the target becomes healthy
  • I havent created a SSL cert (but i’d expect the http endpoint to still send back something)
What i expected
  • curl to get a 200 or 302 response
  • tables to get created in the backend database
  • more logs
  • the exec command that creates the first user password to succeed (see command below)
[passpolt@ip-aaa ~]$ cat docker-compose-ce.yaml
version: '3.9'
    restart: unless-stopped
      APP_FULL_BASE_URL: https://mydomain.com
      DATASOURCES_DEFAULT_HOST: "mysql://auroramysql.rds.amazonaws.com"
      DATASOURCES_DEFAULT_PASSWORD: “xxx”
     - 8090:80
     - 8091:433
  gpg_volume:
  jwt_volume:
docker-compose -f docker-compose-ce.yaml exec passbolt su -m -c "/usr/share/php/passbolt/bin/cake \
                                passbolt register_user \
                                -u user@email.com -f username -l name -s /bin/sh www-data
Thanks for the detailed description of what is going on.
First thing that comes to mind is, did you create a passbolt database on your RDS instance?
If not you’ll want to log into the RDS instance and run:
CREATE DATABASE passbolt CHARACTER SET utf8mb4 COLLATE utf8mb4_unicode_ci;
This is from the CE from Source page.
After that could you run the healthcheck and migration status commands from the docker troubleshooting page and post the output?
This will give a bit more info on where the issue is.
ok thanks this has moved me forward; the healthcheck script confirms the app can connect to the database, but there are other errors
I cleared out the docker volumes and db, ran the db migration script as per the message in the healthcheckoutput
It seems like it didnt generate a self-signed cert either; so maybe some of the automatic actions that are supposed to happen on first run dnot happen or didnt happen in my case. I can create a cert and populate it via the variables and see how that helps. it looks like this is the root cause of most of the errors.
the error ‘Could not reach the /healthcheck/status with the url specified in App.fullBaseUrl’ → this will be tough to solve if there isnt a way to ignore because that URL resolves to a load balancer which only fwd’s traffic when the target group is healthy. so it will be chicken and egg. unless there’s a way to override or make that first test use a differnet url like localhost
I’ll try these things and let you know
Below are two things, the healthcheck output and also the output of the export fingerpprint command
www-data@5385af052d20:/usr/share/php/passbolt$ export PASSBOLT_GPG_SERVER_KEY_FINGERPRINT="$(gpg \
  --home $GNUPGHOME\
  --list-keys \
  ${PASSBOLT_KEY_EMAIL:-passbolt@yourdomain.com} | \
  grep -Ev "^(pub|sub|uid|^$)" | tr -d ' ')"
gpg: error reading key: No public key
www-data@5385af052d20:/usr/share/php/passbolt$ ./bin/cake passbolt healthcheck
 Healthcheck shell......Warning Error: file_get_contents(/etc/passbolt/gpg/serverkey.asc): failed to open stream: No such file or directory
In [/usr/share/php/passbolt/src/Utility/Healthchecks/GpgHealthchecks.php, line 456]
2022-12-02 18:40:21 warning: Warning (2): file_get_contents(/etc/passbolt/gpg/serverkey.asc): failed to open stream: No such file or directory in [/usr/share/php/passbolt/src/Utility/Healthchecks/GpgHealthchecks.php, line 456]
Warning Error: file_get_contents(/etc/passbolt/gpg/serverkey_private.asc): failed to open stream: No such file or directory
In [/usr/share/php/passbolt/src/Utility/Healthchecks/GpgHealthchecks.php, line 458]
2022-12-02 18:40:21 warning: Warning (2): file_get_contents(/etc/passbolt/gpg/serverkey_private.asc): failed to open stream: No such file or directory in [/usr/share/php/passbolt/src/Utility/Healthchecks/GpgHealthchecks.php, line 458]
 [PASS] PHP version 7.4.33.
 [FAIL] Debug mode is on.
 [PASS] Full base url is set to https://passbolt.alpsecpocs.eu
 [PASS] 26 tables found
 [FAIL] The public key file is not defined in config/passbolt.php or not readable.
 [HELP] Ensure the public key file is defined by the variable passbolt.gpg.serverKey.public in config/passbolt.php.
 [HELP] Ensure there is a public key armored block in the key file.
 [HELP] Ensure the public key defined in config/passbolt.php exists and is accessible by the webserver user.
 [FAIL] The private key file is not defined in config/passbolt.php or not readable.
 [HELP] Ensure the private key file is defined by the variable passbolt.gpg.serverKey.private in config/passbolt.php.
 [HELP] Ensure there is a private key armored block in the key file.
 [HELP] Ensure the private key defined in config/passbolt.php exists and is accessible by the webserver user.
 [HELP] you can try:
 [PASS] Using latest passbolt version (3.8.3).
 [FAIL] A valid JWT key pair is missing
 [HELP] Run the create JWT keys script to create a valid JWT secret and public key pair:
 [HELP] sudo su -s /bin/bash -c "/usr/share/php/passbolt/bin/cake passbolt create_jwt_keys" www-data
 SMTP Settings
 [FAIL] 10 error(s) found. Hang in there!
Many thanks
When you cleared out the volumes and DB did you clear all of the volumes, or just specific ones?
The line:
can be safely ignored for now, the container should still accept connections with that being the case.
The GPG issues are something to look more at though. You may need to specify some of these environment variables in docker, which the moving from one docker to a new one page might help shed some light here as well. This could explain the mismatch for the keys.
I would like to re-start this thread again as I have a -partly- similar case:
For some time, I operated PB as a native lxc container (ubuntu 20) with a remote database on another lxc container. Now I migrated to docker compose for the passbolt application, but I still want to keep the data on remote DB.
As a first try I modified the standard compose file to remove the dependency to a local docker container db
version: '3.9'
   # depends_on:
   #  - db
     APP_FULL_BASE_URL: https://passbolt.netzwissen.de
     DATASOURCES_DEFAULT_HOST: "10.10.10.16"
     DATASOURCES_DEFAULT_PASSWORD: "xxx"
     EMAIL_DEFAULT_FROM_NAME: "Passbolt Server"
     EMAIL_DEFAULT_FROM: "passbolt-noreply@netzwissen.de"
     EMAIL_TRANSPORT_DEFAULT_HOST: "mail.netzwissen.de"
     EMAIL_TRANSPORT_DEFAULT_PORT: "587"
     EMAIL_TRANSPORT_DEFAULT_USERNAME: "admin@netzwissen.de"
     EMAIL_TRANSPORT_DEFAULT_PASSWORD: "xxx"
But I still see a shell script restarting in the container, /usr/bin/wait-for.sh
When I use the standard docker-based db it runs stable but now it restarts all the time.
Any ideas how to debug this?
Thanks, Thommie
