Resource path in passbolt API
We’re using passbolt to store our host secrets, and we went with the pro version so we could use folders to organize our machines (and subsequent accounts). Is there a way to also get the path of the resource returned in the API? For example: When I use the API and I request /resources.json, I don’t see the resource path returned, only an uuid for folder_parent_id. Having the actual path there would be useful for scripting and filtering.
Hi @ekollof
Welcome to the forum! And great question.
Since you are a pro version user, can I ask you to reach out to us at support@passbolt.com? We can better assist you there, thanks!
Hi!
I’ll shoot you a mail
