Passbolt Pro Folders API
Hi!
Can someone share and example how to create a folder using the API in Passbolt Pro?
I’m evaluating this piece of automation.
I have been looking into folders as i also have an automation Project.
This is what i have found so far:
GET passboltURL + /folders.json?api-version=v2
	Gets all folders
GET passboltURL + /folders/{folderid}.json?api-version=v2
	Gets Folder
GET passboltURL + /folders.json?api-version=2&contain[permissions.user.profile]=true&contain[permissions.group]=true
	Gets all folders with permissions and users
GET passboltURL + /folders/{folderid}.json?api-version=2&contain[permissions.user.profile]=true&contain[permissions.group]=true
	Gets Folder with permissions and users
POST passboltURL + /folders.json?api-version=v2
	Creates Folder
		Parameters:
			- name	string
			- folder_parent_id string
			- personal bool
POST passboltURL + /resources.json?api-version=v2
	Creates Resource (Password)
		Parameters:
			- name	string
			- description	string
			- secrets	[]secret
			- folder_parent_id string (use this to create a password directly in a folder)
I Really hope we get a proper documentation for folders soon.
Edit: Forgot to Add Folder Sharing
PUT passboltURL + /share/resource/{resourceUUID}.json?api-version=v2
Shares folder
	Parameters:
		- New:    bool (should be true if your not updating)
		- Aco:    string (this should be "Folder" for sharing folders)
		- AcoKey: string (folder id)
		- Aro:    string (what to share with User/Group)
		- AroKey: string (id of what to share with)
		- Type:   int (permission: 1 is read 7 is update 15 is owner)
