We are running passbolt in EKS env using image: passbolt/passbolt:latest-ce-non-root
our deployment env variable for APP_FULL_BASE_URL = https://someurl/passbolt/
on login, we only see this:
How do we fix this ?
Thanks,
Nikesh
Thanks,
Nikesh
Hi @nikesh Welcome to the forum!
Have you made sure your server can resolve the domain you are using? Can you ping the domain from the command line?
You may want to provide more info as is requested. About the Installation Issues category
yes, we are able to access the domain.
We have created the service for the passbolt and route the request using the istio virtual service:
here is our service yaml: (yes, we have deployed the passbolt on port 8080)
apiVersion: v1
kind: Service
metadata:
labels:
app: passbolt
spec:
- port: 8080
targetPort: 8080
selector:
app: passbolt
type: ClusterIP
and here is our istio VS.yaml
Can you provide links to documentation you are working with related to these? What guide(s) are you following?
If it’s not a passbolt documented setup, we can try to follow what you are attempting.
Hi @nikesh
APP_FULL_BASE_URL
is only for https://someurl. As you are trying to host passbolt on a sub-dirrectory /passbolt
, you should define this one with the APP_BASE
environment variable:
APP_FULL_BASE_URL=https://someurl
APP_BASE=/passbolt
I got this information from passbolt configuration file
The environment variable for this configuration is defined here.
Let us know if it works for you.
