I’ve been trying to connect to passbolt using postman, i’ve been following the instructions in the manual here Passbolt Help | Authentication in passbolt, but I’m getting the error: The route /auth/login is not permitted with JWT authentication
I’ve checked and i have JWT enabled
This message indicates that you are trying to use a JWT to a non JWT enabled endpoint. They are only two /auth/login and /auth/logout both are used to initiate cookie driven sessions. This is because we don’t want users to have both a valid cookie session and a JWT (e.g. basically to avoid beeing authenticated with two methods at the same time).
Not sure why you need to access these endpoints with a JWT set. Can you explain what you are trying to do?
