Hey everyone,
I recently followed the guide on Marius Hosting (How to Install Passbolt on Your Synology NAS – Marius Hosting) to successfully install Passbolt on my Synology NAS. However, I’m experiencing an issue with Step 30 of the guide. When I generate the link and try to open it, instead of being directed to the browser extension page, I’m redirected to my router interface.
I’m not quite sure what’s causing this issue and how to resolve it. Has anyone else encountered a similar problem before or have any suggestions on how I can fix this? I appreciate any help or advice that you can offer.
Thank you in advance!
[PASS] PHP version 7.4.33.
[PASS] Full base url is set to https://passbolt.#####.myds.me
[HELP] cURL Error (60) SSL certificate problem: self signed certificate
[PASS] 30 tables found
[HELP] you can try:
[PASS] Using latest passbolt version (3.12.0).
SMTP Settings
[FAIL] 7 error(s) found. Hang in there!
