I need help. We need to update our passbolt server to V3 and upgrade the OS to Ubuntu 20. But please could someone assist with the proper process with regards to this as i know just doing an update breaks the server?
Currently Ubuntu 18.04-LTS, current Passbolt version 2.13.5/3.2.3. We are not 100% sure of the installation method as this is a server that was previously configured by another member that has since left.
The files from the old process were together and commonly found in /var/www/passbolt. The new package will produce new file locations. If you search the forum for /etc/passbolt you’ll find many threads about this upgrade process which rolled out earlier this year. But follow the link above to get started.
Did you use the ubuntu package? If so you can execute:
sudo dpkg-reconfigure passbolt-ce-server
Then, you select Yes to reconfigure the nginx server
The next screen will depends of your https configuration:
You have a certificate on the server: choose manual
You are using let’s encrypt: choose auto
You are using http: choose none
In order to be sure you can execute at the end of the wizard: sudo systemctl restart nginx
If you still have issue, then we will have to see the log of nginx
