Is it possible to use Passbolt Desktop and browser extension with Passbolt CE? Same question for Passbolt mobile? If this is possible, what do I need to do to accomplish this?
Thanks
Thanks
Yes,
Browser extension, CLI, mobile, desktop app are just clients.
You need to configure your clients with an encrypted private key, and use a passphrase to unlock that private key. So you can even configure 10 browser profile. What you need in the end is a private key to setup your client.
Max
Do I need to generate a private key? I don’t see anyway to connect my browser extension to my self-hosted Passbolt server.
If you don’t have a recovery-kit (which in fact is just a copy of your private encrypted private key) you can download one on a already configured browser extension.
Just go to the following url: https://<YOUR_PASSBOLT_URL>/app/settings/keys there is a button Private on top to download it.
Awesome, thanks.
I don’t know where to get the recovery-kit at.
You can get the recovery-kit from Profile > Keys Inspector > Download Private ![]()
Thanks, I appreciate all the help. Now I can get this installed and start using it.
