ldubost
November 13, 2019, 2:02pm
1
Following up on the post
I’m trying to configure our Passbolt instance (2.10.0) to use a Yubikey OTP.
As explained in the guide here: https://help.passbolt.com/configure/mfa/yubikey.html
I’ve created an API key. However it seems that the Key secret I got is too long for the passbolt entry field.
The key I received is 27 characters long in the form of xxxxxxxxxxxxxxxxxxxxxxxxxxx= while the documentation seem to show a secret key of 23 characters in the form xx/xxxxxx/xxxxxxxxxxxx=
Maybe there is a change in the Yubik…
which is closed and I could not find how to reopen it, I wanted to mention that the fix mentionned in that post is not enough
There is also a client side check in passbolt.js
rule:“/{10,128}$/”
which would need to be changed to
rule:“/{10,128}$/”
However after doing this while I have been able to setup yubikey, when going to the user profile and trying to enter the OTP, I got an “An Internal Error Has Occurred” which I don’t know how to debug
ldubost
November 13, 2019, 4:38pm
2
I take back the “An Internal Error has Occured”. This was due to php-curl missing on the server side. This part is working now.
So only the passbolt.js needs an update to the client side rule
Ludovic
system
Closed
November 19, 2019, 10:08am
3
